where can I buy these clamps from
Submitted: Wednesday, Jun 09, 2004 at 23:48
ThreadID: 13643 Views:2516 Replies:5 FollowUps:3
Hi guys, I was wondering if any of you know where I can buy a set of these "pop up" style rings to hold my fridge down. I am in Sydney.
I got the pic from Black Widow site, Click on my pic to see what im refering too.
Thanks all Angelo
Reply By: V8troopie - Thursday, Jun 10, 2004 at 00:39
cokeaddict, you can get those from marine chandlers, try Withworths (6 shops in Sydney) or Bias marine, they have them in their catalogue.
these recessed rings are also used on boat decks.
Klaus
AnswerID: 62559
Klaus
AnswerID: 62560
Reply By: V8troopie - Thursday, Jun 10, 2004 at 00:41
try Withworths or Bias marine chandleries.
Klaus
AnswerID: 62561
Follow Up By: V8troopie - Thursday, Jun 10, 2004 at 00:43
Ooops, sorry about the multy reply - its not the easiest forum to reply to :-)
Klaus
FollowupID: 323854
Reply By: cokeaddict - Thursday, Jun 10, 2004 at 09:01
Ok Thank you very much guys. Very much apreciated. Hope I can return the favour one day.
Enjoy your LONG WEEKEND !
Cheers Angelo
AnswerID: 62580
Reply By: Angus (SA) - Thursday, Jun 10, 2004 at 13:36
Angelo
Those from boat chandlers will be stainless steel and could cost a bit.
If you don't plan getting stuck in deep water then then you can get them at any decent Hardware Shop for 4 or 5 bucks zinc plated only. I'm sure these are what Black Widow uses. From memory they are called "Hatch-Pulls" or similar.
Bought some for my rear shelf but ended up not installing them as the carpet stopped things sliding around and rely on cargo barrier to stop the fridge killing me in an impact (too much faith??:-)
AnswerID: 62634
Follow Up By: cokeaddict - Thursday, Jun 10, 2004 at 14:21
I just got back from Chandlers,
They had some great stuff there, but unfortunately they dont sell the good quality ones i was after, most were thin plated and pivot on a thin cotter pin setup. Not strong enough for holding down a waeco 80.
But i did find a compromise and will be fitting them in the next few days.
I will duck down to hardwarehouse before i do and see if they carry the solid "Hatch Pulls" if they do I will be installing them instead as the ones i got from chandlers as they are a loop (ring) that threads through the floor on a 3/8 bolt, Id much prefer to keep the top flat for when the fridge is not in the car.
Thank you for you time though Angus, apreciate your help very much
Cheers Angelo
FollowupID: 323948
Follow Up By: Shaker - Thursday, Jun 10, 2004 at 18:09
You will find that most steel fabricators have them.
FollowupID: 323978
