Hi-Lift Jacking Points?
Submitted: Saturday, Jun 12, 2004 at 12:50
ThreadID: 13705 Views:2153 Replies:3 FollowUps:3
Does anyone have any idea about welding jacking points onto the chassis of a 98 GU? I've only got a nissan bar which i'm told will bend very easily if I try to do it off there.. and im aware of using the reece hitch but just need something for the front end of the car.
Any suggestions or heard of how people have done it?
Troy
Reply By: Member - John - Saturday, Jun 12, 2004 at 14:27
Troy, instead of welding to the chassis, why not purchase the Hi lift jack adapter from any of the good 4wd stores, fits over the front hub and also is transferable to other trucks as/if required. If you can't find one in your local stores, I know the bloke that makes them and can provide his name and address etc if you require them. Hope this helps.
John and Jan
AnswerID: 62893
Follow Up By: Davoe - Sunday, Jun 13, 2004 at 16:28
yep best things out we use ones at work made from machined drill rods much easier than jacking up the whole suspension and cheap
FollowupID: 324308
Reply By: Truckster (Vic) - Saturday, Jun 12, 2004 at 21:53
Are you planning on a winch at some stage, maybe save up for a which bar... no issues then.
The issue with the ones over the hubs, if your wheels are stuck down in a rut, which is when you want a high lift (thats their purpose in life), then you cant get it fitted..
AnswerID: 62929
Follow Up By: Member - Troy - Saturday, Jun 12, 2004 at 23:03
I hadn't really planned on getting one.. but i've heard that it makes life much easier...
What sort of money would I be talking about?
FollowupID: 324281
Follow Up By: Truckster (Vic) - Sunday, Jun 13, 2004 at 01:14
Depending on what you want, anything from $400 sec hand, to $1200.. theres some custom ones around now that are pretty trick too..
have a look at
http://www.cheezyracing.com.au/Cr_Product_WinchBars.htm
but theres heaps making this style now.
FollowupID: 324287
Reply By: Member - John - Sunday, Jun 13, 2004 at 10:14
Troy, try the link. John
http://motorcare.com.au/jacadptr.htm
John and Jan
AnswerID: 62966
