Dual Batteries system Jackaroo 99 Model
Submitted: Tuesday, Mar 06, 2001 at 01:00
ThreadID: 138 Views:5638 Replies:2 FollowUps:4
Has any one installed a dual battery system into a 99 model Jackaroo? Also what would are the better systems to install.
Reply By: Joe McDermott - Wednesday, Mar 07, 2001 at 01:00
Ian,
I have a couple of answers here for you :
If you want the dual system for starting (eg if you have the diesel) then I would suggest a walk to your Holden dealer - the latest roo has a dual battery system fitted for the diesel and if you get them to fit it the warranty will not be affected.
If it is for running a fridge or winch etc then check the Pirahna range - they have some great systems.
BUT !
Isnt there always a but !
You may want to check with some of the more liberally minded autoelectricians around, or request the appropriate wiring details from Liemack fridges in SA, as some people are now wiring their batteries to provide 24volts to their fridges (makes for a very fast fridge, but obviously only where this is designed in) and relies on the voltage cutout to protect the starting capabilities of the vehicle.
Choices, choices, choices !
Joe
AnswerID: 255
Follow Up By: Ian Knox - Sunday, Mar 11, 2001 at 01:00
Hi Joe
Many thanks for your comments. I have investigated the Dual battery system by Holden but it appears that it is no long a line item. However I am exploring two options.
1/ The Piranha Dual Battery Kit
2/ Purchase the components separately such as the Dual battery mounts, Battery and a control Kit put out by Jaycar.
Regards Ian Knox
FollowupID: 42
Reply By: Mike Ranger - Friday, Jun 15, 2001 at 00:00
I have the Pirahna system fitted to my 99 petrol jackaroo. It was fitted by TJM Adelaide. The job is very neat, but I wouldn't reccommend doing it yourself.
AnswerID: 635
Follow Up By: Geoff Waye - Saturday, Aug 11, 2001 at 00:00
Mike are you able to take a photo of the job and e-mail me it. I have 2001 petrol and after talking to a 4wd shop it will be very hard job.
FollowupID: 251
Follow Up By: Mike - Sunday, Aug 12, 2001 at 00:00
Geoff, Sorry no photo but 2nd battery goes against passenger side firewall. Means shifting quite a deal of plumbing etc. but most major offroad shops are doing the job regularly. TJM fitted ours (pirhana). ARB & Opp Lock had no problem with tackling the job. One of these may be able to help you. Happy trails, Mike.
FollowupID: 252
Follow Up By: Geoff - Saturday, Aug 25, 2001 at 00:00
Thanks Mike,I got a Quote from a 4wd shop around $1000 including 2 batteries
FollowupID: 279
