Leaky tyre/rim bead
Submitted: Thursday, Jun 17, 2004 at 19:13
ThreadID: 13866 Views:2252 Replies:4 FollowUps:1
Does any one know of any goo that helps to seal the bead against the rim. I've had the tyres off a number of times using tyre pliers fixing various popped beads, but its getting difficult to get a seal again. I've even scrubbed them with abrush to get the dirt off.
Reply By: halfinch - Thursday, Jun 17, 2004 at 21:09
gday Andrew,
What is your main prob, seating the bead or the beads leaking??? If it's leaking beads the best method is to remove tyre and clean the rim up with a wire wheel( if no major dents or dings). Another option might be sikaflex which we tried a few times on atv tyres when i worked at a tyre service. (didn't always work..)
anyway best of luck Halfinch..
AnswerID: 63655
Reply By: Kiwi Ray - Thursday, Jun 17, 2004 at 21:13
Hi Andrew
Go to your tire shop and get a tin of bead seal
Ray
AnswerID: 63656
Reply By: bazzle - Friday, Jun 18, 2004 at 09:52
Clean rim and bead as above.
Then fit HD tubes.
Bazzle
AnswerID: 63715
Follow Up By: Leroy - Friday, Jun 18, 2004 at 12:00
and use soapy water to help the tyre slip back into place.
Leroy
FollowupID: 324897
Reply By: Mrs Diamond - Saturday, Jun 19, 2004 at 15:49
you can also use tyre shine.
not the spray on type but the stuff you paint on.
clean rim and bead spotless and fit tyre to rim .
paint the tyre bead with the black stuff them pump up
AnswerID: 63941
