AnswerID: 65945 Submitted: Thursday, Jul 01, 2004 at 12:49
Utemad
replied:
If you use a 5w handheld (like the GME tx6200) with an external antenna you will get the same range as a fully wired unit witht the same antenna. I would personally go the hard wired unit myself however a 5 watt handheld would do the trick. More expensive than the equivalent hard wired unit though if you are getting the antenna anyway.
As said before on this thread there are many ways of installing a unit quickly and damage free. Silicone can be a strong bond and can be cleaned off quite easily. Also what about putting a cigarette lighter plug on the unit and not installing it at all. GME has a range of aerials (4700) that can be unscrewed easily and can use a variety of length and db aerials.
I have a cheapy Uniden 0.5 watt unit also. Handy during recovery situations or when someone does not have a unit or a unit in the convoy dies. Great for just about any situation for short range
communications really.
My work just bought 2 new Uniden 5w handhelds. Supposedly water and dust proof and amazingly small for a 5w unit. Were only $369 each. Haven't used them yet so don't know how good they are.
Anyway you have lots of options to choose from.
Utemad
Reply 4 of 9
FollowupID: 326817 Submitted:
Thursday, Jul 01, 2004 at 17:09
Mungo Explorer posted:
Some good ideas there, thanks. I just find a handheld unit more versatile: I can wander off with it, take it
fishing, or whatever. So the antenna is really only intended as backup for emergencies: if, for example, I find myself fairly close to a repeater but the little handheld antenna won't quite cut the mustard. I've seen the Uniden 5w and they are very small but maybe not the same quality as a GME or Icom?
