gu patrol sub tank leaking
Submitted: Friday, Jul 02, 2004 at 18:29
mygu4500
The sub
tank has crack along one of the seams on my gu gas/petrol patrol and is leaking petrol, in being fixed at the moment under warranty. I have being told that it is not the original
tank, is there any way of telling eg. nissan stamp somewhere on
tank. Certainly looks bigger then 30 litres.
Cheers Dave
Reply By: Mrs Diamond - Friday, Jul 02, 2004 at 19:39
id be looking at who fitted the lpg.
a lot of times they fitter a bigger sub
tank if they have to remove an originall one to fit the gas
tank
66185
Reply By: mygu4500 - Friday, Jul 02, 2004 at 20:05
Previous owner fitted lpg, when I get the patrol back I will run petrol till nearly empty to work out size of
tank , I dont think the gauge is accurate.
66188
Reply By: Member - Roachie SA- Friday, Jul 02, 2004 at 20:41
Dave,
The standard
tank will have a cover plate underneath it with several holes of about 40mm diameter in it.....mongrel of an idea as little stones get caught in between it and the
tank. The aftermarket tanks that I know of, all have no guard under them and are just a flat bottom surface.
Good luck
66192
Follow Up By: mygu4500 - Friday, Jul 02, 2004 at 21:06
Got no guard on
tank and a flat bottom must be aftermarket, bigger
tank greater range (It needs it) yippie!! Now I've just got to work out the size.
Cheers Dave
327032
