AnswerID: 68926 Submitted: Wednesday, Jul 21, 2004 at 22:20
Richard & Leonie
replied:
We have a 2002 Auto. Just got back from
Cape York going up the Old Telegraph Road. Absolutely no problems with the car. We have TLM 2000 series
suspension fitted with the front torsion bar wound up so the whole car is lifted about 70mm. We also had a second 75 lt tank fitted by Out of town 4WD in Newcastle. We do not have a
snorkel and the maximum water depth we did was 700mm. We used a Michele Sacs blind bought from ARB
Sydney South. Very easy to fit and remove. It created a great bow wave that kept the engine bay dry. I checked the airbox after and noted a little water had got in but it had drained out without even wetting the filter.
We used Cooper ST
tyres (75 instead of 70's) and they performed well. Ran them at the 26 psi recommended by Holden on the dirt but put the rear up to 28 psi
on the road. Dropped them to 18 psi in sand. We did not have space for a spare tyre casing or wheel so I look a couple of radial inner tubes with me. Luckily I did not need them. The closest place for spare Cooper
tyres was Tyrepower at
Cairns and i checked they had them in stock before we set out.
I did bog the car once in sand on the Stewart River but that was my fault going the wrong way. The standard fuel tank does tend to act like a dozer blade but I have learnt to try and ride high on deeply rutted tracks. This is just a matter of knowing where the wheels are. Being lighter than Cruisers and Patrols helps.
The car loaded weighed in at 2450 kgs.
Fuel consumption ranged from 13 lts / 100 to 17 lts / 100.
Changed the air filter on the way back at
Cooktown.
Also fitted an Exide extreme battery before we left.
The only noise we had when we came off the dirt was from the air box where it passes through the inner guard. It squeaked and WD40 fixed it.
Hope this helps.
 | Richard and Leonie, The grey nomads. The afterburner really upsets tailgaters. |
Reply 10 of 10
