80 series Diesel Blows Smoke
Submitted: Monday, Jul 12, 2004 at 07:34
ThreadID: 14583 Views:2224 Replies:4 FollowUps:4
I had my injectors done 20,000 km ago , under acceleration as revs get higher and pedal gets closer to the floor it starts to blow lots of smoke , i re-alinged the pump timing marks and this made a slight improvement , as the smoke gets worse it seems to lose power , harder to breath , could it be possible my mechanic has turned up the flow rate and if so how can i reduce it , also fuel econmey has gone out the window i used to get 330 km from the sub tank now i get 280 km ,any help greatly appreciated
Reply By: sockoh - Monday, Jul 12, 2004 at 07:50
it has done 325,000 km with out any major mechanical work and is a 95 dx with 1hz
AnswerID: 67403
Reply By: Member - Roachie SA- Monday, Jul 12, 2004 at 11:13
Mate,
Far too technical for me to comment on other than to suggest that if it was mine, after 325,000klm, I'd be shouting it a full expert tune-up. Injectors have been done, but pump would need to be overhauled and re-callibrated etc. If it's a turbo model, I would think that may need a bit of a tweak too by now. It could cost you a few hundred bucks (maybe even a grand!!!), but it would be money well spent I would imagine.
Good luck.
AnswerID: 67419
Follow Up By: Member - Sean O (NSW) - Thursday, Jul 15, 2004 at 09:50
thanks for the help it is going to get the works pump , injectors , tappets serviced and a turbo kit fitted
FollowupID: 328553
Follow Up By: Roachie (SA) - Thursday, Jul 15, 2004 at 10:10
Struth mate, you don't muck around, eh?? LOL
Congrats on becoming a member too.
Once you've had the old girl dressed up and given her a new hair dryer, you won't recognise her......
Goodonya
cya
FollowupID: 328560
Reply By: Sam - Monday, Jul 12, 2004 at 14:12
With that many kms I would suggest that your injector pump would be due for reconditioning. 250,000kms is pretty common for the 1HZ.
AnswerID: 67446
Follow Up By: Member - Sean O (NSW) - Thursday, Jul 15, 2004 at 09:52
thanks for the help it is going for a fuul fuel service and get a turbo fitted
FollowupID: 328554
Reply By: Kiwi Ray - Monday, Jul 12, 2004 at 14:47
Hi Sockoh
Check the cheaper parts first
Air intake system and air filter
Exhaust for damage or blockage
tappet settings
Ray
AnswerID: 67451
thanks for the help it is getting a full fuel service and a turbo fitted
FollowupID: 328555
