AnswerID: 291 Submitted: Tuesday, Mar 20, 2001 at 00:00
Joe McDermott
replied:
Peter - you obviously have already realised that the snorkels main use is to source clean(er) air from what is hopefully a less dusty part of the atmosphere. Keeping the air source above water level is normally a lower priority and I suspect that you would not be fording anything much deeper than 30cms with a caravan anyway !
So, if you are never going to be travelling dusty roads or deep fords the
snorkel is not needed.
Foam air filters - This is more of an economics choice than anything, although the relative efficiencies are worth looking at.
Efficiency - Oiled foam filters will trap particulate matter as efficiently and a paper filter, but will retain that efficiency level for longer than paper filters and generally will flow more air as well.
Economics - Oiled air filters are re-useable and so save on the costs of replacing the paper filter every service. They are also user serviceable on trips, so if you do come across very dusty conditions, you can keep your filtration system up to spec much more effectively. As they tend to flow more air than a paper filter they can also keep up with engine demands more easily and a marginal improvement in consumption may be the result.
So, are foam filters worth it ? If you keep you 4WD for long enough to make the investment pay for itself in the cost of paper filters not used then Yes. Or if you are prepared to keep an eye on the filter condition and clean and re-oil as necessary then Yes as the engine will be breathing cleaner air and more of it.
Personally, I have fitted the foam Finer Filter to my truck, but I havent (yet) fitted a
snorkel. However, with a
Cape York trip planned for winter 2002 I will be fitting one.
Reply 2 of 7
