GU DX UHF location
Submitted: Thursday, Jul 22, 2004 at 11:09
Austravel
Were is the most common, place to fit a UHF in the GU??
Reply By: Well 55 - Thursday, Jul 22, 2004 at 12:09
I put
mine under the radio/CD, fits nice and snug.
69011
Reply By: Member - Roachie (SA) - Thursday, Jul 22, 2004 at 12:09
I've got
mine in a neat dash pod made in
sydney by a mob called "Dept of the Interior".
I sent them my radio, speaker and a voltmeter and switch. They fitted it all and it looks like OE.
Others have them mounted down on bottom of dash above either left or right knee. If I was doing it again, I reckon I'd get one of those remote head units and mount it at the back of the gear shift (in front of the ashtray). Main unit could go under
seat etc.
I've got shytloads of gear......HF remote head sits in front of gear shift (blocks cigi lighter socket, but that has a plug permanently located for mobile phone in-car kit)......I've removed the whole ashtray unit and replaced with a piece of craftwood to which is screwed 2 speakers (one for mobile phone, other for
HF radio)........the cradle for the mobile phone sits in the little hollow behind the transfer case lever.
There's plenty of room, you just have to be brave enough to drill some holes in the plastic.
69013
Reply By: Member - Chris M (QLD) - Thursday, Jul 22, 2004 at 12:40
When I pick
mine up shortly, I'm going to remove the big mother of a standard stereo, and fit a more athsetically pleasing head unit in there and put my uniden uhf right underneath it.
Dunno if common, but it worked in the GQ.
69021
Reply By: Martyn (WA) - Thursday, Jul 22, 2004 at 14:41
Austravel,
In my GU the main bit is under the passengers
seat, the remote head is mounted just in front of the gear levers slightly to the right and the remote speaker is just to the left of the remote head. Looks quite neat even if I say so myself.
69037
Reply By: Member - Rick (S.A.) - Thursday, Jul 22, 2004 at 16:19
If you send me your email address, I'll send back some pics of my GU in which I have located the unit in the dash above the glovebox. This is
the spot in which the airbag would be, if you had that model. But you don't, so give it a whirl.
69054
Follow Up By: Austravel - Tuesday, Jul 27, 2004 at 10:48
Some photo's would be great. Address is r.kearney@cqu.edu.au
330070
Reply By: Member-Steve (Pilbara) - Thursday, Jul 22, 2004 at 16:40
I have mounted
mine (slimline GME) in the console where switch blanks are next to the passenger/console storage, bit of mucking around to fit and not the easiest to see sometimes but out of the way. A dash pod or smaller stereo would be the ideal spot.
69058
Reply By: GOB & denny vic member - Thursday, Jul 22, 2004 at 17:25
ours is in o/head console hf main box up the bqack with remote head fitted to console works for me
steve
69061
Reply By: howie - Thursday, Jul 22, 2004 at 19:19
agree with rick, remove the glove box temp,unscrew the panel where the airbag isnt ( 6 screws from memory) . cut out plastic behind panel (keep screw holes).
create shelf from bottom screw holes to solid metal bar (which will be revealed).
my remote head has the bracket fixed with solastic under the a/c recirc area, never budged for years.
one of the firms mentioned above (min of the interior i think) sells something for this area and has a cutaway picture on their site.
good luck
69085
Reply By: Austravel - Tuesday, Jul 27, 2004 at 10:51
Thanks for all the ideas.
69848
