Wheel bearing nut size for GU
Submitted: Monday, Aug 02, 2004 at 11:34
Austravel
Does anyone know if the wheel bearing nut in the GQ is the same size as that in the GU??
Reply By: desray - Monday, Aug 02, 2004 at 13:03
No the GU has a round nut ( not hex) you will need a special tool with pins to turn them ,, or a hammer and small punch .
70876
Reply By: JamieMac - Tuesday, Aug 03, 2004 at 14:38
That depends on the year model. As said above some have a round locknut that is retained pins thru a hole in
the nut.
Mine has a f'n big nut and I have a spanner for it but have not measured. Can do if you don't get an answer soon.
jamie
71069
Follow Up By: Austravel - Tuesday, Aug 03, 2004 at 14:50
Hi jamie,
Thanks for the offer I might take you up on it.
Mine is a 2002 model, I made a tube spanner for the GQ and had hoped it would suit. If you get a chance to measure the spanner it would be appreciated, no rush.
331293
Follow Up By: JamieMac - Wednesday, Aug 04, 2004 at 14:34
Might have confused you due to my confusion!! The info I gave is for a GQ which you have the spanner for already. I have not looked at my GU bearings yet, 3000km so no surprise threre I suppose.
The later GQ had the round retaining nut thingamy so I suspect as the first reply states that the GU is the same?
Should have read the question better. Sorry mate.
Jamie
331470
Follow Up By: Austravel - Thursday, Aug 05, 2004 at 08:52
No dramas, thanks for the info, I'll check
mine out when I strip it down next.
331547
