AnswerID: 70926 Submitted: Monday, Aug 02, 2004 at 17:53
Martyn (WA)
replied:
Gajm,
I was in the same place you where about three years ago. My 4.2 had about 220 Klms on the clock, after much discussion and a bit of extra cash I went for the Safari Turbo, yes it did make a difference, worth while I reckoned. Downsides, I rebuilt the engine because I wanted to be on the safe side considering the K's, when I stripped the engine I found the head had a small crack in the pre comp chamber to the exhaust valve, so I was up for another cylinder head, I tried for quite a few months to find a secondhand head, rare as rockinghorse poop, so that was a grand down the tube buying a new one, it was worth while in the end. I fitted a pyrometer in the exhaust as part of the installation to keep an eye on exhaust temp you will be surprised how high it can get when towing up relatively small gradients. I tried a three core radiator initially didn't have much success I went back to my old two core and never had a problem, new thermostat and a recored radiator worked for me, towed up hill and down dale, no problem at all.
I also had spotlights fitted, but I did remove the big NISSAN badge off the grill this made quite a diference.
If your taking the engine out get the aftermarket clutch kit from Nissan it's about half the price of the genuine article. Don't go for a cheapy, they rattle after about 30 k's.
The internal web casting is different between the genuine 4.2 TD and the standard engine you need to be aware of this when you put your boot into it, you will get more block flex.
I could go on for ages about this episode in my life if you want more info let me know I don't want to
bore the other forumites to death, you might of just wanted a simple answer. In my opinion, yes it's worth it in the long run.
Reply 1 of 8
