HELP NEEDED GQ1991 AUTO
Submitted: Friday, Aug 06, 2004 at 08:43
ThreadID: 15335 Views:1727 Replies:3 FollowUps:1
Driving today when i heard a bang came from the back of car now car starts but wont ddrive,reverse or go in first or secong gear car revs but wont go anywhere any info would be a great help or am i up for dollars
Reply By: Truckster (Vic) - Friday, Aug 06, 2004 at 09:21
Bloke in our club had this at the property at Easter. The oil lines had blocked, and the whole thing was fubar. Had a complete rebuild, with the improved valvebody, and lockup kit installed for about $4000.
What state are you in? if in Melb, try KB Autos in Berwick, they helped me out in the past.
AnswerID: 71465
Reply By: tour boy - Friday, Aug 06, 2004 at 10:03
check the pinion on the rear diff. See if the tailshaft spins when trying to drive. or just see in nutural if the tailshaft turn by hand all the way around.
AnswerID: 71469
Reply By: Member - Michael- Friday, Aug 06, 2004 at 10:12
Rob
You can try putting it into 4WD Hi range and see if it will move, if it does then the problem is probably in the rear axle
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 71471
Follow Up By: Member - Jeff M (WA) - Friday, Aug 06, 2004 at 13:10
Yeah Michael is right, you've gotta find out if it's the gearbox, diff or drive shaft/uni's etc.
If the bang came from the rear of the car, hopefully it's not a gearbox, but only a little exploring will find that out.
FollowupID: 331674
