Nisan Patrol ST 1992 (RB30)
Submitted: Monday, Aug 09, 2004 at 04:50
ThreadID: 15409 Views:4562 Replies:6 FollowUps:5
Hi there has anyone changed a clutch on a Nissan GQ ST 1992 (RB30)
I've got a big garage , lots of tools and I recently changed the water pump.
Thanks for your help.
Reply By: Truckster (Vic) - Monday, Aug 09, 2004 at 10:40
Gearbox is VERY VERY VERY (VERY) HEAVY...
Unless you have a lift kit, or a lot of clearance under the car, as in 35in tires, get it done.
we have done a mates TD42 and nutha mate of his RB30. GQ was insanely heavy, and RB was really a bitch to get back in... Just the angles, and clearance issues.
You can do it, but for the hassles, lost fingers, knuckles, and bleeding, I would pay
YMMV
AnswerID: 71849
Follow Up By: 2ndLow - Monday, Aug 09, 2004 at 11:14
Truskster, how about on GU?....are they as strong as GQ(same weight?)
FollowupID: 332013
Follow Up By: Truckster (Vic) - Monday, Aug 09, 2004 at 11:25
Nothing on a GU is strong as a GQ :D~
FollowupID: 332014
Follow Up By: Don Murray - Monday, Aug 09, 2004 at 20:27
thanks for the info its exactly what I needed
Cheers Don Murray
FollowupID: 332092
Reply By: mr diamond - Monday, Aug 09, 2004 at 13:13
gday don.
as truckster said there big and heavy not as big as the 4.2 but big.
i cheated when i done mine i pulled out the motor heaps easier that way.
also when you order the clutch kit make sure you get the month of the gq.
im not sure of the dates but there is a slight difference in the clutch plate.
AnswerID: 71866
Follow Up By: Don Murray - Monday, Aug 09, 2004 at 21:25
Mr Diamond thanks for response,
i found an internet company , nipponautomotive.com who quoted me for the clutch kit, but he said my chassis no did not register on his computer.
Is there any chance you could find me the part no.
The details are:
Nissan Patrol 1992
Type: WSGY60
No of Chassis : JN1WSGY60A0037284
Model : WSGY60FM
Color trim : AH3 K
Axel : FS5R30A HG43
Plant : W
year of manufacture 01/92
Cheers Don Murray
FollowupID: 332113
Follow Up By: mr diamond - Wednesday, Aug 11, 2004 at 20:40
no problem don ill post it tommorow ffor you.
also being only a 3ltr i wouldnt bother with a heavy duty one.
FollowupID: 332385
Reply By: Martyn (WA) - Monday, Aug 09, 2004 at 13:51
Don,
People have been very badly injured removing and replacing gearboxes in GQ's as mentioned they are very heavy. I like someone else took the easy option and lifted the motor out, mine was a 1992 4.2 ST TD. It might seem a tad over the top but I found it a lot easier and also a lot safer. You could hire an engine hoist if you don't have one they're relatively cheap when you consider the cosequences. If you want to replace the gearbox front seal this can also be done with the engine out and you standing in the engines space. Good luck.
Keep the shiny side up
AnswerID: 71869
Reply By: Austravel - Monday, Aug 09, 2004 at 14:16
Be careful, one of the retaining bolts for a wiring harness that attaches to the gearbox is also the retaining bolt for a ball bearing used on an indent in the gear shift ( I think). The mate/mechanic that did mine found out the hard way. When undone it allows the ball to fall into the gearbox.
AnswerID: 71874
Reply By: Member - Crocbit (NT) - Monday, Aug 09, 2004 at 15:14
G'day,
AS above, they (gearbox,tfr case) are very heavy, and difficult to handle (you NEED ANOTHER JOINT BETWEEN ELBOW AND WRIST!), so I had mine done by dealer 18 months ago, only about $450, well worth it, also spend the extra and upgrade to "extreme" clutch kit....well worth it.
If you have to do it yourself, get a few mates around and a lifter....
Don
AnswerID: 71883
Reply By: mr diamond - Thursday, Aug 12, 2004 at 17:58
gday don.
i couldnt find your post theres a cpl of pages missing lol.
now the clutch kit for yours is part number.r173n
and the price i can get them is $132 inc
hope this helps
AnswerID: 72321
