Rodeo spacer template
Submitted: Monday, Aug 09, 2004 at 18:47
ThreadID: 15431 Views:1814 Replies:3 FollowUps:3
Does anyone have a template of the 4 bolt ball joint spacer for the Rodeo?
Alternatively if anyone has a spacer that is not installed could you please scan it. The measurements should come out okay.
Thanks.
Utemad
Reply By: Leroy - Monday, Aug 09, 2004 at 20:05
Thinking I should of took a photocopy before I sold mine.....oh well!
Leroy
AnswerID: 71926
Follow Up By: Utemad - Monday, Aug 09, 2004 at 21:36
Even better, you should have sold them to me :-)
Utemad
FollowupID: 332117
Follow Up By: Leroy - Monday, Aug 09, 2004 at 23:47
you could always rip a ball joint out and make a template from cardboard.
Leroy
FollowupID: 332133
Follow Up By: Utemad - Tuesday, Aug 10, 2004 at 09:45
What I want to do is have the spacer ready to go when I pull the suspension apart so as to minimise down time.
However I will probably do like you said. I have some of that stiff yet thin cardboard (project paper?) that I think would make a great template.
Utemad
FollowupID: 332152
Reply By: signman - Tuesday, Aug 10, 2004 at 12:32
Sorry mate...but when you make your set, you may wanna make a set for me too??? I just bought a pair of the low profile poly?? bump stops off ebay for $10. Apparently the kids use them for lowering their rodeos.
David
AnswerID: 72014
Reply By: signman - Monday, Aug 30, 2004 at 09:39
G'day Utemad
How did ya go with the ball joint job??
Let me know direct on:
op(dot)support@tsn(dot)cc
Thanx
David
AnswerID: 74486
