285/75/16 MTR's fitting onwheel carrier on GU...
Submitted: Tuesday, Aug 10, 2004 at 09:56
Member - Chris M (QLD)
Howdy all,
Well, it's all happening very fast. My 'guy' has obtained some new, sexy 285/75/16 Goodyear MTR's on some new Monsoon ROH Alloy
wheels (5 of) for the new beast. The
suspension is a 3 inch extra heavy duty Dobinson kit and the new kinsley steps arrive today!
My question is, does an MTR of the above size fit on the spare wheel carrier on the
barn door of a DX GU Patrol. I had a look the other day and I'd think not??? Any wonderful ideas on spacing the carrier out and if it's strong enough to do so?
If you are chasing
suspension of the above breed or tyres, I did get them extremely cheap and will get you the same deal if interested!
Chris.
Reply By: Member - Captain (WA) - Tuesday, Aug 10, 2004 at 10:37
Hi Chris,
I have a 285/75 Cooper ST's on my GU. When I initially put it on, you cannot fully tighten the rim to the holder as the tread edge touches on both sides of the door. But you can open the little door still!.
So I fabricated a 25mm RHS spacer and also incorporated a HF antenae holder and a rear worklight post. I had to obtain some longer bolts for the holder and it works very
well. Its been on for over 20,000kms now and all seems fine, no door sag etc... Member message me if you want some pics.
Good luck fitting out the new toy, I reckon thats half the fun!
Captain
71994
Follow Up By: madcow - Tuesday, Aug 10, 2004 at 11:03
i would be interested in those pics as
well if you wouldn't mind.
dave.
charlton@ap.effem.com
332159
Follow Up By: Member - Captain (WA) - Tuesday, Aug 10, 2004 at 12:40
No Problems, will try and send them tonight.
332171
Follow Up By: madcow - Tuesday, Aug 10, 2004 at 12:52
Cheers thanks mate! Just for the record I put eyebolts where the third row seats were bolted in to give me more tie down points.
332174
Follow Up By: rolande- Wednesday, Aug 11, 2004 at 10:23
Captain,
Would be interested in the photo's also if that is O.K. with you
uhuforrest AT yahoo DOT com DOT au
thanks
rolande
332325
Reply By: Leroy - Tuesday, Aug 10, 2004 at 11:59
Chris,
You have a couple of options. Get the wheel spacer off a TI or buy a Kaymar spacer which also holds their light.
Leroy
72004
Follow Up By: Member - Chris M (QLD) - Tuesday, Aug 10, 2004 at 12:01
Leroy,
Ok, next question, where to get the Kaymar Wheel Carrier spacer? Nissan would probably want $65,000,000,000.00 for a TI spacer.
Waiting on some photos from Captain from his engineered jobby, but appreciate where I could get such an item?
Cheers mate,
Chris.
332163
Follow Up By: DARREN - Tuesday, Aug 10, 2004 at 13:22
Chris, About $80 at ARB, that where I got
mine (on Leroy's advice)
332177
Follow Up By: Leroy - Tuesday, Aug 10, 2004 at 20:17
$80 is about right.
Leroy
332266
Reply By: Member - ramp - Tuesday, Aug 10, 2004 at 17:24
hi chris, just put the wheel on backwards and use a cover so you cant see the inside. cheers rob
72055
Reply By: rolande- Wednesday, Aug 11, 2004 at 10:24
Chris,
If you want the kaymar spacer and work light holder, the price goes up to around $240. Could get a good one fabricated as per Captain for less than this.
rolande
72129
Follow Up By: Member - Chris M (QLD) - Thursday, Aug 12, 2004 at 10:11
Thanks Rolande!
332470
