Dual batteries 1994 4runner 2.8 diesel
Submitted: Monday, Jul 22, 2002 at 00:00
ThreadID: 1546 Views:3506 Replies:2 FollowUps:5
Back in May, Sam Hall replied to my request for info re dual batteries in 1994 diesel 4runner. I would like to know how you got on with the installation in your vehicle. Also any other ideas from anyone would be appreciated
Reply By: Member - Sam - Tuesday, Jul 23, 2002 at 00:00
Werner, as we speak, its in getting the system fitted. I had to settle to have the second battery installed in the tray in a battery box. There was just too many uncertains about making modifications to the components in the engine bay and to the bay itself to fit the second battery there. I could have opted for a battery size that would have fitted, but the capacity would simply not be worth it. Will let you know when i get the truck back. Cheers, Sam.
AnswerID: 5052
Reply By: Paul Rundel - Tuesday, Jul 23, 2002 at 00:00
Werner, I recently converted my 1996 dual-cab 2.8l diesel with a dual battery system by repositioning the standard airfilter housing (requires careful measurements when cutting and welding the re-aligned air intake and manifold outlet) closer to the firewall and utilising the existing space for the battery set-up.
The original air intake arrangement (positioned behind the front right headlight) was removed and replaced with a Safari snorkel which lines up directly to the newly positioned airfilter inlet, resulting in a very compact conversion.
AnswerID: 5057
Follow Up By: Member - Sam - Tuesday, Jul 23, 2002 at 00:00
Werner, I had the option of heading down the same track as Paul did. My only problem was time and money. I may still look into a similar setup. I also have a Finer Filter air filter and this takes up a significant amount of space. One option I have is to replace this with a custom unit to fit the space available. I may look into this one day, but for the time being, had to settle for the battery in the tray. cheers, Sam.
FollowupID: 2158
Follow Up By: Werner - Wednesday, Jul 24, 2002 at 00:00
Paul, sounds like you've gone down the path which I am about to go. I also was going to put a snorkel on the inlet. I am going to have another play with the filter tonight and the car is going to my mechanic on Fri for a service as well as a look into the dual battery situation. Will keep you posted as to how I go. Thanks for the replies Paul and Sam.
FollowupID: 2178
Follow Up By: Werner - Monday, Jul 29, 2002 at 00:00
Hi Paul, having reread your reply, it seems as though our engine layouts may be different although we have the same size engine. On my vehicle the air intake is currently on the passenger side next to the headlight with the air filter sitting directly behind the headlight, its axis running in an east-west direction. The main driving battery sits directly behind the driver side headlight. The intake manifold for the engine is located on the passenger side. Could you please clarify your setup ?
Regards, Werner
FollowupID: 2248
Follow Up By: Paulr - Tuesday, Jul 30, 2002 at 00:00
Werner, as you correctly pointed out, my original set-up is as per your description i.e. air filter housing (cylindrical pressed steel unit) running east west directly behind the passenger head light and the main battery on the opposite side, behind the driver's headlight.
I then moved the steel air filter housing into a north south axis, parrallel with the engine and close to the firewall. This is where the difficulty comes into the modification. Both the air inlet and outlet pipes were cut, repositioned and welded in place. The air inlet pipe was measured, cut and shortened so as to line up directly with the snorkel connection which comes through the body and into the engine compartment above the leaft front wheel. The air hose supplied with the snorkel kit connects straight onto the new air inlet pipe (no extra bends, etc required).
The air filter housing discharge pipe was also modified so as to line up almost directly with the original intake manifold arrangement. The existing rubber pipe which connects the existing air filter housing and the manifold was cut shorter (~20cm total length) and now connects the two perfectly.
Underneath the original air filter housing is a flat plate already spotwelded onto the body for a second battery position. I welded up a larger frame and positioned this ontop of this plate with the battery now sitting very close to the radiator top up water bottle. This top up bottle is secured with a 8mm bolt to the grill cross member and slightly to the left of this 8mm bolt is a threaded bolt hole which I've used to secure a battery bracket.
The complete system now consists of a second battery positioned east west directly behind the headlight, the air filter housing positioned north south between the engine and body panel (wheel panel) with the rear of the housing close to the fuel filter which is positioned on the firewall.
To access the air filter element the second battery must be removed so that the three clips and double cover can be removed.
Werner it probably sounds complicated but once I got the measurements and alignment done it was pretty straight forward. It's now a pretty compact arrangement with the added bonus of not loosing any space in the well body where most auxillary batteries are fitted as well as not having to run long battery cables between the two units.
FollowupID: 2265
Follow Up By: Werner - Wednesday, Jul 31, 2002 at 00:00
Thanks very much Paul for the detailed reply. I will pass it on to my mechanic. Werner
FollowupID: 2283
