GU front wheelbearings
Submitted: Monday, Aug 16, 2004 at 12:22
ThreadID: 15598 Views:2174 Replies:4 FollowUps:9
Hi, I have just tightened the left front wheelbearings on my 2000 GU 4.2 turbo having found it to be loose when I changed the tyre. They were serviced 10,000 k's ago. I found only the left side was loose and on removing the free wheeling hub found the screws holding the locking washer were in place. I have spoken to a couple of mechanics who have said this appears to happen on GU's and don't know why. Apparently you have to regularly check the front wheel bearings. Has anyone else heard of this? Cheers.
Reply By: Flash - Monday, Aug 16, 2004 at 12:29
Haven't heard of it, (that doesn't help you, sorry) and have done a number of mates bearings for them.
But Q. Did you repack them yourself?
Perhaps they weren't done correctly by somebody else (or by you?)
I wouldn't trust SOME mechanics as far as I could throw them.
AnswerID: 72781
Follow Up By: warthog - Monday, Aug 16, 2004 at 12:42
Thanks Flash, done by a mechanic whom I trust. He did warn me to keep an eye on them, said that although the bearings are larger than on a yota they are too close together. Didn't see any evidence of wear or discolouration/metal in the grease
FollowupID: 332891
Reply By: madcow - Monday, Aug 16, 2004 at 13:03
You wouldn't be able to tell me the bearing numbers or sizes could you?
AnswerID: 72789
Follow Up By: warthog - Monday, Aug 16, 2004 at 15:08
Sorry I dont know the numbers or sizes though i do know Consolidated Bearing Co do akit hope that is some help
FollowupID: 332905
Follow Up By: madcow - Monday, Aug 16, 2004 at 15:13
i was just curious to know so as to have spares on the next big trip. I can get them pretty cheap.
thanks anyway
FollowupID: 332908
Follow Up By: Member - Ed. C.- Monday, Aug 16, 2004 at 15:25
G'day madcow,
Made a note of (cone) #'s when I repacked mine a while ago..
('99 TD42T)
Inner... (NSK) .. HR 33110J a1
Outer... " .. LM 501349
Hope this helps.. Regards, Ed. C.
Confucius say.....
FollowupID: 332912
Follow Up By: madcow - Monday, Aug 16, 2004 at 15:32
Thanks Ed,
It was one of those items that are always handy to know. I carry spares that probably don't need to be carried but you never know. i have an 03 4.2tdi and they should all be the same.
FollowupID: 332916
Follow Up By: madcow - Tuesday, Aug 17, 2004 at 09:48
SKF
FollowupID: 333019
Follow Up By: madcow - Tuesday, Aug 17, 2004 at 09:51
OOPS! SKF also do a kit $65.00 a side including seals. Do not know their part number though!
FollowupID: 333021
Reply By: gumagoo93 - Monday, Aug 16, 2004 at 14:24
Repacked the bearings on my GU on Saturday, replaced the hub seals ect.....no problems leading up to that so far.....I will definitely keep an eye on them, although I don't see how the nut can work loose when the screws go through the washer & into the nut itself.... as you know the washer has tabs that slot into the stub axle....good to know these things!....cheers...Don
AnswerID: 72800
Reply By: NissanofOld - Monday, Aug 16, 2004 at 19:31
GU and GQ bearings are much the same (as are the MQ except for the locking nut). When repacked, they need to be torqued to a certain setting to bed them in. It's quite possible that if not correctly torqued, they can loosen up slightly and will need re-torquing. Those who do it by feel, and not knowing the right feel, are most likely to not to get it quite right. In reality, this can happen to any 4x4 (or even 2by), so those mechanics that say it's just a GU thing, really don't know what they're talking about.
One thing to note. Because of the camber on Australian roads, the left wheels feel the effect far more than the right hand wheels ie more strain on the left side. So if the left side hasn't been set up just right, it's likely to go out of kilter first. No big deal, just be aware of it.
AnswerID: 72840
Follow Up By: warthog - Tuesday, Aug 17, 2004 at 14:34
thanks for your reply, I'm hoping the nut was not tensioned correctly as you say. However one of the mechanics I spoke to used to work at Kittle's Nissan here in Alice Springs and he tells me loose left front wheel nuts were a common occurence on GU's that did alot of dirt work, another fella tells me because the wheel bearings are close together lateral force is exerted on the stub axle and the lock nut by the bearing cage resulting in wear and play. I havent done too many k's in the car so I guess I'll just keep an eye on it and see what happens. There haven't been any responses indicating a problem so hopefully your right and it's bullbleep. Cheers Chris.
FollowupID: 333077
Follow Up By: NissanofOld - Tuesday, Aug 17, 2004 at 18:00
There are two ways to checks the bearing pretension, rough, but reasonably accurate.
The first test is after driving for say 10-20 km without a lot of brake use, stop and feel how warm the hubs are. If they are roughly the same temp and warm, but not overly hot, they should be OK.
The second test is to raise each wheel and grab the tyre at the top and the bottom and try to rock the tyre along the axle length. You should not be able to get any movement. If there is movement, you should remove the hubs and give the lock nuts a slight tightening.
Over-tightening of lock nuts and over-greasing of bearings is their biggest killer.
FollowupID: 333111
