how to disable abs on 100 series ifs
Submitted: Monday, Aug 16, 2004 at 12:53
ThreadID: 15600 Views:3001 Replies:9 FollowUps:6
can anyone point me in direction of someone who may be able to help me install switch or something to be able to disable abs on td 100series(or pay them)
dont care whether its legal or not-but also dont want a butcher job
one more nail in coffin of 100 series ifs(only joking)
Reply By: fozzy - Monday, Aug 16, 2004 at 12:54
ps-im in melb
AnswerID: 72786
Reply By: Vince NSW - Monday, Aug 16, 2004 at 13:00
Why not just pull the fuse when you are on the dirt. That way you can put it back in when back on the black top and no switch for the INS co to worry about if the worse happens
Vince
AnswerID: 72788
Follow Up By: fozzy - Monday, Aug 16, 2004 at 13:06
thanks vince-will try tonight-i read from archives that someone tried that and it also disabled brakes as well.
FollowupID: 332895
Reply By: Vince NSW - Monday, Aug 16, 2004 at 13:12
My fronteria has a 60amp fuse and when pulled the breaks work well. Only doun side is the warning light on the dash.
AnswerID: 72794
Follow Up By: fozzy - Monday, Aug 16, 2004 at 13:14
i can certainly live with that
will try myself tonight
will have to read manual to find(first time for everything)
FollowupID: 332896
Reply By: Truckster (Vic) - Monday, Aug 16, 2004 at 13:57
Easiest way mick is to trade it in on a GU.. :)~
AnswerID: 72796
Follow Up By: fozzy - Monday, Aug 16, 2004 at 14:08
seating area not big enough-good diffs though
FollowupID: 332898
Reply By: GO_OFFROAD - Monday, Aug 16, 2004 at 14:43
Just need an ecu wiring diagram for the brakes, and remodel the pin that makes the vehicle think its in low range, where the ABS is esentially disabled.
This can be done with switch also to same pin, to make ecu think its in low range, and if its auto, the shift pattern for the auto may change gear higher in the rev range while it thinks its in low range, aness you include remodelling the pin the auto ecu uses to think its in low range.
Any good auto elec should be able to get a diagram, and do the required works.
AnswerID: 72807
Reply By: Member - Karl - Monday, Aug 16, 2004 at 16:25
Mate,
Try www.lcool.org - they have a lot of info on both the 80 series and 100 series including on how to do it in the 80 series - it might be similar to the 100 series.
AnswerID: 72819
Reply By: Bob H - Monday, Aug 16, 2004 at 18:04
Fozzy, Karls advice is right on the money. the lcool site actually describes an 80series but i think a 100 serties would be the same
AnswerID: 72829
Reply By: Hero - Monday, Aug 16, 2004 at 19:51
Be careful when pulling the fuse, you may lose brake vacuum and ultimately brakes altogether.
AnswerID: 72842
Follow Up By: MrBitchi - Tuesday, Aug 17, 2004 at 07:41
You have to be joking, right??? All modern brakes are vacuum assisted. As long as the engine is running you have vacuum and therefore brakes. I don't think anyone would design a system that would cause the brakes to fail simply because of a blown (removed) fuse!
FollowupID: 332997
Follow Up By: Hero - Tuesday, Aug 17, 2004 at 09:17
Try it my friend, and you will see.
FollowupID: 333012
Follow Up By: MrBitchi - Tuesday, Aug 17, 2004 at 10:25
Maybe on Toyota's but I drive a Pajero and I KNOW I can remove the fuse with no ill effects.
FollowupID: 333030
Reply By: mark d - Tuesday, Aug 17, 2004 at 16:34
Hero, you are right.
I have been in a 100 series cruiser with the fuse removed. You hear a slight warning buzzer , abs light is on and after about 20 seconds , no brakes.
AnswerID: 72960
