80 series wiring diagram (radio)
Submitted: Monday, Aug 16, 2004 at 17:38
ThreadID: 15607 Views:11644 Replies:5 FollowUps:8
Gidday All,Can anyone out there supply a wiring diagram for the speakers on a 1994 l/cruiser GXL 80 Series.I need to connect a new Mp3 CD player.Just the colour coding is all I need for the speakers.4 speakers in all.
Thanks Locallaw.
PS I rang the local toyota dealer who said they dont have it ????
Reply By: Bob H - Monday, Aug 16, 2004 at 17:53
Goodday locallaw, check back in here approx 9pm 2nite and i will have all the info you need or alternatively send ph no and i will ring you. regards Bob
AnswerID: 72827
Follow Up By: locallaw - Monday, Aug 16, 2004 at 18:40
Gidday Bob H I will be here at 9 pm.
Thanks Locallaw
Prefer not to post Phone number for obvious reasons.
FollowupID: 332944
Reply By: Utemad - Monday, Aug 16, 2004 at 17:59
Easiest way is to find the power wires and earth so you can exlude them.
Then get the wires you think are the speaker wires and make this simple tool. You will need a C size battery and two short bits of wire. Solder one wire to each end of the battery and then strip and tin the other ends of the wire.
Once this is made you can touch them to the wires in the cars plug and when you hear a speaker make a crackling popping noise then you have found that speakers wires. Then to find out which is positive and which is negative you can have someone look at the speaker (shine a torch through the speaker grill) and see if it is popping in or out. To get the right polarity it needs to pop 'in'.
Do that 4 times and you'll have your wiring code. You will probably be able to figure out the code after you have found one or two speakers using this method. Just pop them anyway to double check.
You can use any battery but I use a C size as that seems to give a better crackle. This will do no harm to your speakers.
Have fun.
Utemad
AnswerID: 72828
Follow Up By: Member - Jeff M (WA) - Monday, Aug 16, 2004 at 18:07
Neat idea with the battery Utemad, yeah I agree just work it out, once you've eliminated electric arial, power, ground, acc etc etc it's just the 4 speakers to go! Easy!!
Rating, 3.5/10 swear words.
PS The surf was a 6/10 swear words as they have a factory amplifier in the back (hidden somewhere!!) which requires a relay to be triggered, which is somehow linked to the electric arial also, heaps of fun!! LOL
The ol 80 should be a pretty simple process.
FollowupID: 332940
Follow Up By: Utemad - Monday, Aug 16, 2004 at 18:17
Lots of those Jap imports have amplifiers in them as standard. Pain in the arse. We just removed most of them as they aren't needed if you have a quality head unit. But then you need to run new wires or fiddle with the existing ones.
The amps run off the power antenna so they are only switched on when the stereo is on. Although some stereos have two wires for this as the better ones will only have the antenna up when the radio is on so they need another wire to be on whenever the stereo is on.
Fun fun fun.
Utemad
FollowupID: 332941
Follow Up By: Member - Jeff M (WA) - Monday, Aug 16, 2004 at 18:22
Yeah when I origionally fitted it I was getting a humming/clicking noise out of one of the speakers, couldn't figure out how to stop it, then when I re-wired the electric arial so I could bybass it (stop it from going up when in the bush listening to mp3's) it solved the problem, now it sounds great!
FollowupID: 332942
Reply By: locallaw - Monday, Aug 16, 2004 at 18:38
Gidday All,Thanks to everyone who have replied to my request.I now have the answer to the problem and i will put your ideas into action.I will be waiting and watching for any other replies.One other thing is the radio I am fitting has 2 power wires.One is connected to power constantly and the other is only powered when the key is on aux is this right.
Thanks Locallaw
AnswerID: 72831
Follow Up By: Member - Jiarna (SA) - Monday, Aug 16, 2004 at 18:51
Yes. My Pioneer radio/CD/stacker has 2 power wires. BTW my LC80 GXL has an amplifier in the back, but doesn't work. Now I know why - I don't have a power antenna.
FollowupID: 332945
Follow Up By: Utemad - Monday, Aug 16, 2004 at 20:57
One power to accessories and the other to battery. The plug in your Cruiser will have both. Some brands use the battery wire to draw the current and the acc only to tell it to turn on. However others take the current through the acc and the battery wire only to hold the memory settings.
For best performance you should make sure that whichever wire _Affordable_Storage_Drawers.aspx the current in your new unit has a larger diameter wire in the factory plug (you can tell by looking at the inline fuses that came with the radio. Big fuse=current draw wire).
Even then the factory wiring is probably not up to an aftermarket unit. I find it best to wire the earth to something metal and solid in the mounting hole rather than wire it into the plug. Also run a new current drawing wire to the ignition (either acc or battery wire dependant as I said before).
However if you couldn't be bothered to do that it will still work fine most of the time. You would only notice it at high volume/bass. The radio lights may dim and you might hear a clicking noise through the speakers.
Hope I haven't confused the ------- out of you.
Utemad
FollowupID: 332972
Reply By: locallaw - Monday, Aug 16, 2004 at 21:14
Gidday Utemad,I just checked all of the wires for the radio and can only find one power wire which is via the aux switch (no power when switched off).There is no constant power source at all anywhere in the loom.It looks like I will have to run a constant power source to the radio.
Seeya Locallaw
AnswerID: 72856
Follow Up By: Utemad - Tuesday, Aug 17, 2004 at 08:16
I would be surprised if there was no battery wire. However I can't remember what was in a 1994 Cruiser. It should have been a digital. Can't remember the brand (Fujitsu or something sounding similar?). If it had station presets and/or clock it has to have a battery wire to keep the memory. Check your fuses to see if there is a blown one. Although that wiring diagram will tell all.
Easy enough to run a new wire and as I said you will probably be better off anyway.
Utemad
FollowupID: 332999
Reply By: Bob H - Monday, Aug 16, 2004 at 21:31
Have wireing diagram but i am still trying to work out how to send it through the system.
regards Bob
AnswerID: 72861
Follow Up By: locallaw - Monday, Aug 16, 2004 at 21:54
Gidday Bob H,You can send to locallaw@hotmail.com
I will get back to you later as I have just recently got out of hospital(hernia op) and am a bit sore (doing too much on this radio).
20 staples holding my gut together.
Catch you later Locallaw
FollowupID: 332978
