trailblazer,autofridge or reefer
Submitted: Monday, Aug 16, 2004 at 19:46
ThreadID: 15611 Views:13905 Replies:17 FollowUps:28
Hi looking at buying a camping fridge somthing to last (not plastic crap), I think i'm down to three, trailblazer,autofridge or reefer. The trailblazer r.c special looks good ($2200 for a 70 ltr) . I don't know much about the reefer (web site only).thanks Hilli
Reply By: pjd - Monday, Aug 16, 2004 at 19:54
Ive got a trailblazer & its the best acc money could buy for your 4x4 dont waste money on over seas plastic crap
AnswerID: 72843
Reply By: NissanofOld - Monday, Aug 16, 2004 at 20:18
Have had an Autofridge for over 12 years (Australian made by the way) and it's been just about everywhere without letting us down once. It's different to all the other fridges, but works a treat. Years ago was tested in one of the 4x4 mags and came out as the most durable and low current draw fridge of all. Haven't seen it compared for some time.
AnswerID: 72849
Follow Up By: -OzyGuy- - Tuesday, Aug 17, 2004 at 08:42
A quick followup to the 4x4 Australian fridge test.
Average Amp draw for non-plastic fridges as tested:
39 Ltr Autofridge 4.6
60 Lt Trailblazer 5.2
50 Lt Reefer (Liemack) 3.8
The Reefer (Liemack) was the only (only) fridge to drop from +35 ambient temp down to -15 temp within the 3 hour test period, taking only 55 minutes, the fridge then cycled on/off three times within the ballance of the 3 hour time period.
All eight (8) other fridges tested failed to achieve -15 within the three hour test period from an ambient of +35.
The Reefer (Liemack) achieved -22.4 in only 90 minutes.
The Reefer (Liemack) went from +25 down to Zero degree's in only 15 minutes.
The Autofridge went from +25 down to Zero degree's in 168 minutes.
FollowupID: 333001
Follow Up By: NissanofOld - Tuesday, Aug 17, 2004 at 09:15
The Autofridge is certainly slow when it comes to this sort of test and I would not recommend it to anyone if they're into rapid freezing (I don't think it will even go down to -15). However, for long-term camping, it's the next best thing to a Chescold. The tests that I read about, compared the actual daily current usage and the Autofridge blitzed all of the others. It's not for everyone, but those who have one seem to be very happy.
FollowupID: 333011
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 10:38
these sorts of tests are crocksheit
when shopping for a dometic fridge do you ask the salesman which of the two ie the LG fridge as compared to the Fisher and Paykel can get to -23C quicker...has absolutley nothing to do with abilty to perform efficiently...and they couldnt tell you anyway...thats why they have *ratings...the more the better Yes a bigger fridge can have as many stars as the next...but it Will Use more power .. why?
cos its the ratio of required output duty (watts refrigeration) as compared to electrical input (watts (but electrical watts))
if you put a big enough compressor in any fridge you could get it to pull down to -40c in 5 minutes but this not what we want...-23 can be considered too cold for camping excursions...15 is ample if you have icecream...and possibly -12/10 otherwise if camping is not say over a months duration where product may deteriorate
FollowupID: 333036
Reply By: Nudenut - Monday, Aug 16, 2004 at 21:33
i built a copy Trailblazer...7yrs old and still going
I am a fridgie so i was able to do it...would have gone plastic skin (outside) except that i couldnt get a plastic skin blown at a good price so i used alloy instead.
That said there does not seem to be anything wrong with plastic skin ...waeco?.
reefer use too much energy so beware
engel are good also
autofridge...dont know enough about
anything with 'DANFOSS' compressor should be good.
that means trailblaza and waeco..... Engel use their own. reefer use a 240v comp which must use a 12 to 240 inverter to get it going and which is inefficient
AnswerID: 72862
Follow Up By: Octane - Monday, Aug 16, 2004 at 23:17
Nudenut
For a fridgie I would have thought you would know more, for the record I've got a Reefer 50ST, excellent fridge but it wasn't cheap.Your energy comment about the Reefer is relevent to how quickly you want something to get cold. My unit uses around 2.8amp/hrs, a modified Danfoss BD50 running at the same speed 3000-3500 rmp, a WAECO on turbo, uses about the same power so the energy assumption needs to be clarified. I reckon your copy fridge Danfoss would run at 2000 - 2500 rpm, its energy level is probably very good, however its abilty to cool would be quite slow. The inverter comments are also interesting, some inverters can be inefficient, however if they've been designed to run the compressor at its most efficient power level which the Reefer unit is designed for then they are quite efficient for the energy they consume. At the end of the day its always a compromise, and its usually the dollars that make that decsion. Value for money my pick would be the Reefer DR60, very similar to WAECO, same make of compressor, the Reefer 60lt unit has the bigger BD50 compressor and sells for about $200 less than the equivalent WAECO. Plastic skin wouldn't bother me both WAECO and Reefer have a good outer casing. Engel used to have a good product but for there price you can do better, they're also made in Thailand now and the quality has really gone South. Trailblazer are a good fridge, but the price is on the high side, you also get a little fridge in a big box. Evakool are OK but fibreglass boxes hairline cracks in the corners, what can you say, price is also on the high side. Autofridge, ideas good, eutectic system. Problem is when the system gets warm it uses a lot of energy to get the temperature back down, price is also a killer. International Luna too expensive, good fridge though. Hell a good Esky with a wine bladder full of Tectaloy will do the job most days.
FollowupID: 332991
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 07:56
Not sure about more earlier models...but i believe they did use a danfoss compressor....mmmmm
Liemack before they became reefer were using a 240v rotary compressor which needed a 12-240v inverter to drive it. Reefer continued with this concept......how-ever...and yes your right....been some time since I have visted reefer site and it looks as though they have dumped the 240v rotary in favour of danfoss compressor..
also I dont beleive it is a 'modified' danfoss....rather i suspect it is standard danfoss...new danfoss compressors are variable speed where as mine is not as it is older version. This has very little impact on energy consumption under normal use and not worth monitoring.
yes trailblaza and my copy are little fridge in big box...next project will fix that ....when and if i get around to it
FollowupID: 332998
Follow Up By: -OzyGuy- - Tuesday, Aug 17, 2004 at 09:11
Nudenut,
can you please post ANY INDERPENDANT TEST RESULT where your statement the Reefer (Liemack) fridge "uses too much energy" will confirm what is only your own personal oppinion?
Reefer still use BOTH compressors, Danfoss and also Mitsubishi rotary, as they actually sell two totally different fridges, one is a plastic skinned Waeco lookalike (Danfoss) and also the (Mitsubishi rotary) Stainless Steel fridge that will still outperform any fridge as has been proven by previous INDERPENDANT tests.
As can be seen in your posts above you have made statements that can be proven to be wrong.
I am offering you the opportunity to prove or correct your statements!
FollowupID: 333008
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 10:18
well,OzyGuy lets put it this way:
lets assume all compressors are equally efficient as others...12v and 240v based on output capacity the compressors uses same amount of current...right! ...but in reality the 240v compressor running on 240v and matched to required duty may be a little more efficient
thats fine but with a 240v being driven from 12v dc power we must use a inverter which generates heat.....and what is heat....losses, electrical losses and thats before the compressor gets to use it!
now, should i also go into the basics of of compresor duty efficiencies ie an oversized 240 volt compressor compared to a 12 volt more closely matched to required duty ie output capacity in watts refrigeration compared to required refrigeration capacity in watts refigeration...nah starts getting to difficult for the layman...and me hahaha
now ozyguy are you able to post any facts or figures and or research to disprove what has been ....get as technical as you like...but keep nuclear energy and its relationship to efficiencies and refrigeration by absorption, generated by said heat losses out of the equation as i'm am a rusty on that subject
FollowupID: 333025
Follow Up By: Mad Dog (Victoria) - Tuesday, Aug 17, 2004 at 12:02
Fridge Test
FollowupID: 333048
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 12:15
what more can i say....do i need to?
except that details of mine isnt there.....probably not worth testing...or would make those others look like overdesigned eskies lol lol
honestly though..i note the trailblaza isnt there though...i wonder why?
FollowupID: 333053
Follow Up By: NissanofOld - Tuesday, Aug 17, 2004 at 12:28
That's an interesting comparison. If I'm reading things correctly, the Autofridge is the third best value for money fridge behind the Liemack and Bushboy.
The one thing I've found owning an Autofridge though, is that it needs air circulation to be most efficient. If you leave it in an enclosed space like a hot tent (bit like the test chamber) it tends to work a lot more (it gets rid of the heat through the side panels). Leave it in a shady, outside area, perhaps with a slight breeze and it works a lot better.
The beauty of the Autofridge is that you can leave it disconnected at camp with the missus and kids and go driving and come back six hours later to a cold beer.
FollowupID: 333058
Follow Up By: Baz (NSW) - Tuesday, Aug 17, 2004 at 13:38
Try turning your computer up the right way i think it might be upside down lol, i use a 3 way Electralux caravan type came out of a 1974 Cub Drifter wouldn't buy anything else.
You notice i didn't say it was better or worse than the ones mentioned.
Baz.
FollowupID: 333067
Follow Up By: NissanofOld - Tuesday, Aug 17, 2004 at 13:51
I had a Chescold for nearly 15 years before the Autofridge. Had to replace it because it was beginning to work poorly and the Electrolux service department said they could not get the parts for this model anymore. Thought I'd try something different and the Autofridge had been out a few years and was getting rave reviews. The Nissan Club members at one of the 4WD shows couldn't speak more highly of it. It's been very good and, as I said, the only thing that beats it for long stays is a Chescold/Electrolux. I use it as a beer fridge when not camping, so it's never been turned off since I got it.
FollowupID: 333069
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 17:22
BAz i think his computer is the right side up...it was nissanofold who was upside down
Nissanofold the liemack (by the "fridge test") is the worst...
the list is in best to worst order. forget about cost ...just look at the efficinecy ratings...the higher the number the better it is!
FollowupID: 333102
Follow Up By: NissanofOld - Tuesday, Aug 17, 2004 at 18:13
You're right, for some reason, I missed the critical statement of Best to Worst - I'll blame work interfering and causing me to scan. For the price you pay for the Autofridge nowadays, I don't consider it value for money either, but I do like the way it performs.
As I said, it really does start to run more if it's enclosed in a hot area and can't dissipate the heat through the sides (heat soak starts to go back into the fridge unlike the other types). While driving, it's not a problem, but at camp you just have to know where to store it.
FollowupID: 333116
Follow Up By: rolande- Tuesday, Aug 17, 2004 at 20:14
Nudenut,
Have you seen previous posts on this subject??? A particular "poster" seems to pop up only on this questions and defends to the death his personal choice of fridges, usually attacking anyone with a different view. Sounds like a manufacturer trying to push their product????
Just wondering
Rolande
FollowupID: 333157
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 21:34
nissanofold,
keep the skin in shade..it allows the unit to work more easily
and going by the stats it aint that far out...not like the last
FollowupID: 333180
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 21:42
rolande,
i hope your not refering to me as a err the 'manufacturer'
me i am but a humble fridgie who built his own and will not make for others................well ,...i might if i ever decide to get off my ass and make one that I Want and others might want too..(almost just as easy to make 6,7 or 10 as it is one)
if your not refering to me ...no i have not noticed the posts by him/her or anyone else informed
FollowupID: 333183
Follow Up By: NissanofOld - Wednesday, Aug 18, 2004 at 07:13
Nudenut
You're dead right about keeping it in the shade (guess that applies to all fridges, but especially this one) and I've found that on searing hot days, if you drape a wet towel over the fridge, it helps quite a bit. A bit like the Coolgardie Safe idea.
FollowupID: 333214
Follow Up By: rolande- Wednesday, Aug 18, 2004 at 20:46
Nudenut,
No, not referring to you, rather to an argumentative one who goes to extraordinary lengths to argue his case, posts 14859, 14156, 4970, 4872 will explain all. If you do build 10, drop me a line, I may be interested in buying one,
regards
Rolande
FollowupID: 333349
Reply By: redroo - Monday, Aug 16, 2004 at 22:23
I have had my AUTOFRIDGE for approx 12years .The fridge freezer has been fantastic [ Danfross compressor] and only has to be run 2hrs morning 2hrs night depending on how much you open it .Regettably I am about to sell mine but situations change.Thay are a pretty expensive fridge ,thay are AUSTRLIAN made by QUIRKS and thay are worth it.
AnswerID: 72873
Reply By: ianmc - Monday, Aug 16, 2004 at 23:14
Hi HILLI! I owned a Trailblazer for a few years & it was great in the tropics.
Chilled stuff within the hour. Later models have more bells & whistles.
Nudenut was right about the same motors in both!
But he was wrong on the casings. The alloy case in the trailblazer needs to be ventilated reasonbly well as it dissipates the heat thru the alloy whereas the Waeco
can have stuff packed tighly around it except for the fan vents. The Trailblazer did not have a fan as the case was the condensor!
It became a bit too heavy & bulky for me on my own so I went to the much more compact & lighter waeco 45 which works very well & have now encased most of it in 2" soft foam to help it.
Cases sees quite strong but some had lid troubles.
AnswerID: 72877
Reply By: Crackles - Monday, Aug 16, 2004 at 23:33
Both the Trailblazer & the Autofridge are great. TB would suit a permanent installation where you have plenty of room as they are quite bulky.They are however almost bomb proof. The Auto F is more compact and is the most efficient fridge on the market. It's eutetitic (spelling) coolant makes it equally good in the car or for base camping with solar panels.
Both need space around the sides to dissapate the heat but it's that design feature that helps them be so economical.
Cheers Craig........
HZJ105
70 L Autofridge
AnswerID: 72879
Reply By: Member - Brian (Gold Coast) - Tuesday, Aug 17, 2004 at 07:19
Trailblaza was my choice of fridge, we own a 70 litre, although we paid I think $1600 for the standard 70L with 240v power pack and a dual battery solenoid thingy and it is great for what we want... they are big, they are heavy, they are also good and reliable. The extra "body" is due to the insulation, because of this they don't need a "jacket" to keep the cold in! The backup service from Norcoast is very good as well, though you probably won't need it. Like Nudenut, I am a fridgie as well, and have seen the factory and impressed by their standards. Also our fridge slide/storage drawer built by us in the back yard had an error in that we didn't leave enough "breathing space" around the alloy case which as said above doubles as the condensor, but this has NOT affected the operation of the unit in any way.
And it's an Australian made product that IS worth the money.....
AnswerID: 72883
Reply By: fozzy - Tuesday, Aug 17, 2004 at 07:53
73l autofridge-excellent-low power useage
could use without dual batteries when moving
AnswerID: 72884
Reply By: EXTREME1 - Tuesday, Aug 17, 2004 at 08:03
Have you had a look at the Explorer range of fridge/freezers, very similar to the trailblazer but come with a separate freezer section. They are also made in Queensland. From memory the 95ltr was around $2200 the 78ltr was just over $2000 and the 70ltr one just under $2000. Check their website www.explorerfridgefreezer.aunz.com
AnswerID: 72886
Follow Up By: Nudenut - Tuesday, Aug 17, 2004 at 10:47
looks like these might be using the small danfoss condensing units...these have a small condenser fan in addition to the compressor and must more power than a system having natural condensing by ambient air....
But should still be a good fridge
FollowupID: 333038
Reply By: Riki & Paul - Tuesday, Aug 17, 2004 at 10:58
We've had a Trailblazer for a few years now and have never had a problem with it in terms of reliability and/or battery drain.
Has been used in High Country and outback conditions (as well as drink fridge at home on 240v) and has never missed a beat.
Had a plastic evacool/supacool in the past and didn't last thru the first trip - stick with something that can handle real 4wd'ing!!! Buy a Trailblazer.
AnswerID: 72916
Reply By: Scott_G - Tuesday, Aug 17, 2004 at 17:42
Liemack or Reefer are a dog of a fridge that you need a power station to power them
it does not matter what they go down to or how quickly as long as they get there efficiently
stay well away from Reefer
if ya going to buy a Reefer save your money and buy a Waeco with a decent warranty
AnswerID: 72973
Follow Up By: Octane - Wednesday, Aug 18, 2004 at 09:58
Scott_ G
Your thread looks very farmilar to Wommy, (FollowupID: 330775).Maybe your intellectually connected, or perhaps joined at the hip.
FollowupID: 333255
Follow Up By: -OzyGuy- - Wednesday, Aug 18, 2004 at 12:55
Ditto.......
funny how you can ask someone to post any proof at all, ie; test report etc, to a statement they have made, and they continually evade your request!
FollowupID: 333287
Reply By: Utemad - Tuesday, Aug 17, 2004 at 18:13
I use an 80L Engel Combi and I accidentally froze everything in it last trip away. That was everything in the freezer as well as the fridge section. Never had an issue with it. Cost my work $1900. Cost me nothing hahaha.
Utemad
AnswerID: 72981
Reply By: time waster - Tuesday, Aug 17, 2004 at 20:58
the neighbour bought new a reefer went across the anne beadell and the copper hose split no cold beer. alot of money 1800 whenm you can get two engels for that
AnswerID: 73008
Reply By: Solar Panel - Wednesday, Aug 18, 2004 at 18:12
Ozyguy tell the truth not lies
The Amps Test
Unit followed by Average Amps
Autofridge 2.4
Bush Boy 2.8
Bushman 1.6
Evakool 1.9
Engel 1.6
Explorer 2.4
REEFER/LIEMACK 5.6
Vitrifrigo 2.3
Waeco 2.0
I have been reading this forum for a while and have noticed all the misinformation and untruths you post
AnswerID: 73121
Follow Up By: Solar Panel - Wednesday, Aug 18, 2004 at 18:17
you lie that much and have such poor knowledge you do not even know how a Quirks Autofridge works and why it takes longer than other brands of fridges to cool down
FollowupID: 333340
Reply By: -OzyGuy- - Friday, Aug 20, 2004 at 15:17
ADI test
Question;
The test was conducted before Reefer was involved in portable fridges, so how is the name Reefer involved in the test report results, who and more importantly, why, has someone changed the original test report?
Fact;
Due to the number of fridges tested they actually ran out of amp accumulators, so the test numbers were averaged out, (refer table below)
Fact;
They took the highest power load and lowest and used the half way point as the average.
Fact;
the Liemack fridge uses an initial power surge for approximately 2 seconds at start up, the method of averaging the power figures is not an accurate method of collecting power consumption data when the results are then going to be averaged out to get a test result for any fridge.
Fact;
The Liemack with its 300 watt inverter is considerably worse off than the others simply because the initial inverter power surge is also calculated by the amp accumulator as a number, eg; 27 amps, for only 2 seconds, then the running of the fridge at ~6 amps for only 20 minutes per hour, gives an unreasonably high number when it is averaged out. You do the maths.
This can be confirmed by comparing the test result numbers with any of the power numbers stated by the fridge manufacturers and you will see the numbers are different, simply because the averaging method used in the test is not an accurate method of testing fridge power consumption.
Everkool claim: 3.80 amp not 1.90 amp as averaged tested
Waeco claim: 3.75 amp not 2.00 amp as averaged tested
Engel claim: 2.70 amp not 1.60 amp as averaged tested
ARB claim: 2.70 amp not 1.60 amp as averaged tested
Explorer claim: 3.00 amp not 2.40 amp as averaged tested
Autofridge claim: 24.00 amp not 16.25 amp as averaged tested
Are the ADI averaging test methods .... wrong?
or
are all the fridge Manufacturers .... wrong?
How can any test result be considered true, when it differs so drasticly from the recognised manufacturers own power consumption figures?
AnswerID: 73407
Follow Up By: Member - Brett H (QLD) - Tuesday, Sep 14, 2004 at 21:30
Read it thoroughly
Danfoss Compressor info direct fron Danfoss to you
FollowupID: 336193
Follow Up By: Mainey... - Thursday, Sep 16, 2004 at 22:28
Brett H,
I have printed it, and yes read it, and because it was only relevant to the small fridges with the BD35F compressor, I would expect the power consumption to be higher on the models with the larger compressor....
in the graph "Current consumption" at 'zero' they appear to use between 4.0 and 6.2 A, depending on motor speed.
(if I read it wrong, please tell me)
Under "WIRE DIMENTIONS"
Danfoss recomends the following wire size's from the battery to the fridge compressor...
Maxium lengthWire size (Cross section MM2)
8 foot/2.5 mtr2.5mm square
13 foot/4.o mtr4.o mm square
19.5 foot/6.o mtr6.o mm square
32.8 foot/10.o mtr10.o mm square
FollowupID: 336490
Follow Up By: Member - Brett H (QLD) - Thursday, Sep 16, 2004 at 23:23
Follow Up By: Member - Brett H (QLD) - Thursday, Sep 16, 2004 at 23:30
Mainey,
I don't understand how the data is to be interpreted or under what standard or conditions of test the figures regarding current use are defined. I guess the figures can be used as an indicator/ ratio between a heavily loaded compressor and anlightly loaded compressor.
It is good to note the difference the speed of the compressor makes.
Sorry couldn't be of more help.
FollowupID: 336497
Reply By: -OzyGuy- - Wednesday, Aug 25, 2004 at 23:17
ADI Test results
I take it that no one including;
Nudenut, Mad Dog (Victoria), Scott_G, Wommy and Solar Panel
can explain WHY the ADI test report, in the Mad Dog (Victoria) posted link above, on fridge power consumption, are in some cases almost half the fridge manufactures own nominated power figures?
How can these test results be taken seriously, when there is such a huge difference in the numbers?
Everkool ......claim: 3.80 amp ....not... 1.90 amp as ADI averaged tested
Waeco ........claim: 3.75 amp ....not... 2.00 amp as ADI averaged tested
Engel ..........claim: 2.70 amp ....not... 1.60 amp as ADI averaged tested
ARB ............claim: 2.70 amp ....not... 1.60 amp as ADI averaged tested
Explorer ......claim: 3.00 amp ....not... 2.40 amp as ADI averaged tested
AutoFRIDGE claim: 24.00 amp ...not.. 16.25 amp as ADI averaged tested
I again restate the question:
Is the ADI test report .... wrong?
or
are ALL the FRIDGE Manufacturers .... wrong?
AnswerID: 73992
Follow Up By: -OzyGuy- - Friday, Sep 03, 2004 at 02:04
The ADI test results are wrong..........
No person has explained how the published results are so low compared with the actual fridge manufactures own quoted power figures!
However some people still attempt to use these incorrect numbers,
with the full knowledge that they are in fact ... incorrect.
I restate the question:
are ALL the FRIDGE Manufacturers.... wrong? ........ I don't think so!
When reasonable questions are asked, some people can answer them with ease...
In this case the question must be difficult, or is it embarrassing?
FollowupID: 334796
Reply By: Rob/D.Plain - Friday, Aug 27, 2004 at 00:44
I own the 73 ltr Auto fridge, I think from memory similar in size to the 60 ltr Trailblazer. Lives in the back of the 100 series and use it on average once a fortnight for around 8-10hrs for shopping etc. Never had any problems thus far, have a friend with the 40ltr loves it.
Does take a while to cool down but when it is it's easy to keep cold, you might find you need to run it 3hrs in the morning and 3hrs in the afternoon depending on use in the top end. That said I find it a good fridge.
Regards Rob
AnswerID: 74186
