Shower Temps???
Submitted: Tuesday, Aug 17, 2004 at 09:24
ThreadID: 15623 Views:3783 Replies:13 FollowUps:18
Guys,
I have installed a Twine shower, but need about 2000 rpm to get a
reasonable temp out of it.. Spoke to Twine who reckon that nearly every car needs this just to circulate the water. Having said that they were happy to send
me their larger heat exchanger (65mm longer) which I've fitted, but still
need about 1500rpm..
I'm pretty keen for this to work just at idle - am I chasing the holy
grail??
Has anyone else got a Twine (or any other brand) to work at idle?
Is there any way of optimising the flow? Tricks of the trade?
Reply By: Penguin (NSW) - Tuesday, Aug 17, 2004 at 09:35
Hi Ivan
When I installed the Twine I was hoping for the same as you are - when the engine temperature had reached normal operating level I expected the shower to be at full temp. It just doesn't happen. I find that I need about 1300-1400 rpm to heat the water properly. I think its related to flow rate of the engine's water pump. It needs just a little more than idle to properly circulate the coolant.
The other thing you can try is to partially close the valve on the shower head. This will cause the water to travel slower through the heat exchanger and get warmer. Saves water too.
AnswerID: 72899
Reply By: madcow - Tuesday, Aug 17, 2004 at 09:59
Is that a Nissan you are driving? They tend to run a bit cooler than the tojo hence your issue. I have the longer exchanger in my 4.2 tdi and it has to run at 12 -1400 rpm to heat the water. We are drawing it out of high country rivers though!
AnswerID: 72905
Follow Up By: Member - Ivan (ACT) - Tuesday, Aug 17, 2004 at 10:28
Sorry guys,
Prado V6.... ;-)
FollowupID: 333031
Reply By: flappan - Tuesday, Aug 17, 2004 at 10:03
Mine works off idle. 4.5 Petrol Patrol , McPauls HE (glind identical).
I actually struggle with mine , because it gets too hot. I have a Ti patrol , so dfoesn't have a slide heater , only climate control. Makes minute adjustment impossible.
What I'm about to do , as recommended by a couple of others , is to run the HE on a seperate hose circuit , by using "T's" in the heater line , and then fit a slide heater control valve , from a Falcon or Dunnydore. This allows better adjustment , and also adjustment without getting into the vehicle. (I have seen one where it can be adjusted from within the shower tent itself , long cable).
I would also guess that further adjustment could be obtained by using both heater controls , vehicle and remote ones .
AnswerID: 72906
Follow Up By: Michael - Tuesday, Aug 17, 2004 at 20:25
Just buy a 1/2" BSP Ball Valve and 2 hose tails, 1/2 '' BSP x 5/8" tail. Much neater and has a handle on it. Set to the correct temperature and remove the handle. It will cost you $20 total. Just a thought...... regards Michael
FollowupID: 333166
Reply By: Well 55 - Tuesday, Aug 17, 2004 at 10:34
Mine in a GU 4.2D runs very hot at just above idle, this is after the engine is run for 3 - 5 min, with the heater control up high its to hot for me, so have to run it about halfway.
The other way is to re-circ your watre through a bucket till it warms up then have the shower.
AnswerID: 72914
Reply By: Member - Jeff M (WA) - Tuesday, Aug 17, 2004 at 11:40
I had a shower in one of these fandangle things, it was hooked up to a 79 series cruiser with a 4.2EFI TD in it. It was bloody dangerous I reckon, really hot, and it was only idling...
What about these electric ones, are they any good? It just seems like a lot of hassel to me all these bloody hoses and mechanical adjustments, not to mention having the engine going, taping into your cooling system (just asking for more chance of a failure) etc etc.
Am I mad? or am I making any sense? Also I've seen the 12v jobbies for as low as $19, what's the major difference?? (there must be some, because there is such a large price difference).
AnswerID: 72924
Follow Up By: Utemad - Tuesday, Aug 17, 2004 at 13:15
Those electric ones only pump water from a bucket. The pump is submersible so you just drop it into a bucket of water. For a hot shower you need to heat the water first.
I haven't got any shower yet but I am planning to get one of these. I think heating your own water saves a lot of hassle and expense. You can regulate the water temp by adding cold water to the bucket. or just not heating it as much in the first place.
Don't know about pressure on these though.
Utemad
FollowupID: 333063
Follow Up By: flappan - Tuesday, Aug 17, 2004 at 13:21
Can depend on the individual pump.
I have had 2 . One was very good , one . . . crap.
I used one for a couple of months as the pump for my Vehicle shower , and it worked . . . just.
A lot of this depends on an individuals own requirements.
We have used solar showers , heating water , 12v pump for years. Was always a pain.
With 6 of us , the vehicle shower is so much easier , and the family , including wife and 15yo daughter , don't mind too much about going camping cause they can have a shower.
For me it works . . . fuel use . . . . don't care.
FollowupID: 333064
Follow Up By: Member - Jeff M (WA) - Tuesday, Aug 17, 2004 at 16:47
I saw an electric one from Jaycar, twas only about $30 and it heated too as they had it running as a demonstration. Looked ok to me, and I already have pressured water, I just need to heat it.
FollowupID: 333097
Follow Up By: Willem - Tuesday, Aug 17, 2004 at 19:59
I use a plastic bucket. Boil the billy and mix nice hot and cold water to the right temperature. Have decent wash and pour the contents over me for a rinse. Cheapest shower around and no hassle :-)
FollowupID: 333147
Follow Up By: Oz Trekker - Wednesday, Aug 18, 2004 at 09:22
I think you are making sense Jeff - a lot of travellers seem to complicate and clutter their lives with what I believe to be unnecessary gadgets that sooner or later fail.
I subscribe to Willems way - I've been doing it this way for many years and only ever had to replace the billy or the bucket. When travelling in the tropics and water is plentiful, I've got a 12v bilge pump with a length of garden hose attached - works perfect.
Keep it simple.
Jeff
FollowupID: 333245
Follow Up By: Chris (W.A.) - Thursday, Aug 19, 2004 at 00:56
Perfect way to utilise water.
Get a container about a few inches deep and fairly wide to catch your runoff. Run your glind/twine from it and constantly recycle the water by showering in it.
Once you want a proper rinse down keep a 9L bucket of fresh water next to it to drop the intake pipe into for the final "cleansing".
I long for one but used to run flexi clear pipe from my 'rack tank' to coiled copper in the fire and back using a small bilge pump or natural convection. Heat 45 L in no time.
As mentioned you can get carried away with stuff like this but at the same time you have to get brownie points from the wife and kids (girls).
FollowupID: 333366
Reply By: Tim - Tuesday, Aug 17, 2004 at 12:27
I had a twine in my TD jack and it will be going in my new TD prado soon. I found that if I ran the engine for a while it would run at idle for a few minutes but it quickly took all the heat out of the engine and went cold, to have a stable warm shower I needed about 2k to 2.5K rpm. Up in alpine country I would have to run it at up to 3k, when camped in one remote place for a week with 8 people showering once a day you definatley notice the fuel but hey all luxuries come at a price.
You basically have 4 variables, fresh water temp, fresh water flow, engine temp and engine coolant flow, some of these you have very little or no control over but thats basically all you can adjust to achieve the perfect shower.
Tim
AnswerID: 72930
Follow Up By: 1 Mark - Tuesday, Aug 17, 2004 at 18:36
Tim
when you had this fitted to your T/D Jack did you use cruise control (if fitted ) or something else to build up the revs. Interested to know as I am seriously thinking of purchasing the twine for my vehicle.
Thanks in advance
FollowupID: 333128
Follow Up By: Tim - Tuesday, Aug 17, 2004 at 18:46
Mark
Firstly I can only pressume you have a jack? If thats the case, have a look on the acc. pedal and you will see a hole with a slot taken out of it (its hard to describe). What I did was I got a piece of thin threaded bar about 250mm long and put a few nuts on it and then made a small bracket out of a little piece of aluminium angle with a hole the same as on the acc. pedal and rivited it to the steel bar that is under your steering wheel. Insert the threaded bar between the 2 and adjust the nuts to the desired RPM.
If that doesn't make sense let me know.
Tim
FollowupID: 333132
Reply By: Member - Michael- Tuesday, Aug 17, 2004 at 12:48
Hi Ivan
I've got a home made shower fitted to my GU 3LTD Patrol and I found that it reaches Bloody hot after idling motor for about 6min. I found that the temperature can be controlled somewhat by increasing or decreasing the heater control in the cab.
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 72933
Reply By: Member - Moggs - Tuesday, Aug 17, 2004 at 14:01
Re: Twine shower temps - also worth consideration is the type and length of hose you are running from the heat exchanger to the shower head. Met a guy recently who complained of cold showers - he was running the shower hose for about 5 meters and it was clear thin plastic.
I have a Twine in the Pathy and run it at about 1,500 rpm which gives a hot shower.
AnswerID: 72945
Reply By: Member - Roachie (SA) - Tuesday, Aug 17, 2004 at 15:00
Ivan,
My experiences (with the Twine) are similar to others. As far as I'm concerned, the biggest factor is the temperature of the input water. If you're using water out of a stream in the high country (or anywhere else for that matter), if it is real bloody cold, the only option is to recirculate it for 5 to 10 minutes. Stick your hand in the bucket and the temp will be slightly warmer. But lift the shower head out of the water and spray it onto your hand and it should be just about right.
I have a Patrol 4.2 TD and usually hand throttle it up to about 1100rpm.
I couldn't begin to imagine running my motor @ 2500 to 3000 rpm like one of the other blokes said. My biggest sin is forgetting to turn the heater control full on and then wondering why the water isn't getting hot!!! (silly ol' fart!!) LOL
AnswerID: 72950
Follow Up By: Michael - Tuesday, Aug 17, 2004 at 19:44
What do you mean, Little johnny pull it into drive @ 3000 revs whilst daddy was standing in front of the vehicle when he was having a nice warm shower!!!!!!!
FollowupID: 333140
Reply By: Michael - Tuesday, Aug 17, 2004 at 15:42
Ivan, Hi ,,, How long is the standard barrel length of the Twine??
AnswerID: 72957
Follow Up By: Member - Ivan (ACT) - Tuesday, Aug 17, 2004 at 20:30
Hi Michael - current one is approx 335 mm (measured in the dark ;-)
I understand this is 65 mm longer than standard
FollowupID: 333168
Follow Up By: Michael - Tuesday, Aug 17, 2004 at 21:15
thanks Ivan
FollowupID: 333176
Follow Up By: Voxson (Adelaide) - Wednesday, Aug 18, 2004 at 07:37
Hiya Ivan... Is your picture taken on the Rig Road?
FollowupID: 333221
Follow Up By: Member - Ivan (ACT) - Wednesday, Aug 18, 2004 at 07:47
Mate - good effort picking that!! - not just Simpson, but even which road!!
click here for more
FollowupID: 333226
Reply By: GO_OFFROAD - Tuesday, Aug 17, 2004 at 16:45
You have installed it correctly, so the heater water and water to be heated run opposite directions through the exchanger?
I prefer the circulate and heat idea, so you can have a shower without the motor running.
But I have insulated the exchanger, the delivery hose for hot water, modified the inside of my glind unit, and it gets hot enough on the first pass, but if you turn the water on and off, you have to wait for it to cool before using it again with the tap on the hand piece.
Easier to stop start with same temp water from bucket.
AnswerID: 72961
Follow Up By: Member - Ivan (ACT) - Tuesday, Aug 17, 2004 at 20:37
Hi mate - no, water going in same direction.... I rang Twine and asked them about this one because to do it how you and the instructions say would have meant two additional U turns.. John from Twine said it would make no difference..
I should try that next..
FollowupID: 333169
Reply By: Michael - Tuesday, Aug 17, 2004 at 19:11
HI Ivan, This is a subject that comes up every now and again and always has a mile of replies, mostly negative. I think this is so because it has so many variables. As someone said above that there is engine coolant temp, engine water pump flow, fresh water flow rate and fresh water in temp. If you test it at home in the winter, the water from the tap could be as low as 10 deg C. In the summer it could be as high as 20 deg C from the same tap. I have done that exact test, so the figures are correct. Helton tested their shower with incoming fresh water at 20 deg C, so 10 deg C freshwater coming in to the exchanger will make the shower head temp 10 deg C lower, probably too cold to use. Also if you bought a Twine pump, i think its about 12 litres a minute, if you are using it at that rate , there is no way the exchanger will cope with that. 4 litres a minute is probably maximum, thats enough to shower under. So i think you will have these things into consideration, maybe collect your own data and make a decision on which way you are going to go. Also , you can cut both car heater hoses and insert tee pieces into the cut ends and bypass the cars heater tap, run the water directly to the exchanger.In reply to your question about finding the Holy Grail, It is possible to run at idle, I have a spare, all copper 3" diameter similar to the Twine but much shorter (240mm), it has the added advantage of female BSP fitting on the diameter instead of the end so it is much more compact and you can choose the fittings you want and at any angle you need, if you use M/F elbows on the coolant connections. I tested it on a Hilux petrol and it outputs 48 deg C at idle, 3.75 litre per minute through the shower head. I was short of time so i didnt get readings at higher revs . I'm not too far away from you, i am happy to lend it to you, if you have the time to compare it. You have a petrol engine so it will output similar readings.
It will mount in your Twine brackets so there is not too much mucking around. B est regards Michael
AnswerID: 72989
Follow Up By: Member - Ivan (ACT) - Tuesday, Aug 17, 2004 at 20:41
Thanks for all of that Michael - might give it a run bypassing the heater switch.
FollowupID: 333170
Follow Up By: Michael - Tuesday, Aug 17, 2004 at 20:46
Let us know how you go, This one i have here is not of a single coil. Its a totally different animal. You may be surprised. You need 48-50deg for a cold night at about 4 LPM. regards Michael
FollowupID: 333171
Reply By: Member - Bob - Wednesday, Aug 18, 2004 at 08:57
Guys,
use a baby-arse-wipe (Huggies or similar) every day to wash face, arm-pits, then bum (in that order). On special days use the billy heated to desired temp to pour over head for shampoo, then the other bits. If you pass a shower - use it.
AnswerID: 73056
