DUMB QUESTION no 101
Submitted: Thursday, Aug 19, 2004 at 15:52
ThreadID: 15684 Views:1911 Replies:8 FollowUps:8
With a vehicle with 2 open diffs or an ineffectual lsd (no crowing patrol owners) being effectively a 2wd (1 front 1 rear) what happens during a steep hill descent - do you only get engine braking with the 2 drive wheels? or all 4?
Reply By: duncs - Thursday, Aug 19, 2004 at 16:44
Davoe,
That is right. In fact you only ever get the benefits of engine braking form the wheels that have traction. Therefore, in your steep decent if it was on bitumen for example you would get good engine braking because the wheels all have good traction. If however you were to lift a wheel, then you would lose traction to the whole of that axle. Just like when you are going uphill and you lose traction to one wheel then the other on the same axle stops driving as the one with no traction spins.
That is why diff locks are effective going up and down hills.
So, because I own a Nissan, I recommend you buy one, or fit diff locks to what you have now. :)
Duncs.
AnswerID: 73273
Reply By: Member - Captain (WA) - Thursday, Aug 19, 2004 at 16:47
Hi Davoe,
All depends on the traction. If all 4 wheels have equal traction, then full engine braking. If say one front and one rear have virtually zero traction, then virtually zero engine braking. Exactly the same principle as when driving the wheels, except your braking, not accelerating.
I noticed a significant improvement on certain steep downhill sections after I had a front difflock installed. It basically kept the engine braking working even when a wheel hit a particualrly slippery section.
Captain
PS. there are no dumb questions, just dumb answers!
AnswerID: 73274
Reply By: Davoe - Thursday, Aug 19, 2004 at 17:05
thanks guys food for thought. I guess the biggest difference with up hill and down hill is that uphill a wheel without traction spins and down hill it slides - neither desirable
AnswerID: 73278
Reply By: Member - Brian (Gold Coast) - Thursday, Aug 19, 2004 at 18:20
Thats a damn good question Davoe.... looks like I've learnt something from this too!!! And the post above about the diff lock is food for thought as well!!
AnswerID: 73292
Reply By: Member Eric - Thursday, Aug 19, 2004 at 20:02
I believe the above to be incorrect . When you are going down hill , you cannot brake traction like in a up hill event . If a wheel is air born , the other will turn at the same speed as the rear wheel . This is caused because of the lock in the transfer case . 2 tail shafts turning at the same speed. Now if you do have a fear of the above mentioned . All you need to do is apply the brake slightly and you will create equal drive to both wheels front and rear .
AnswerID: 73315
Reply By: Voxson (Adelaide) - Thursday, Aug 19, 2004 at 21:58
Now i have a question guys....
I have always been under the belief that when going downhill especially and when loose crap with a steep decent is present and one of the front wheels (with no diff lock present) starts to skid,,,, doesnt the other front wheel start to turn at double the speed because of the action with the side gears?????....
Which is why we feel like pick up speed in spit and spurts when this situation arises..... I might be only momentarily but is the correct?...
AnswerID: 73334
Follow Up By: Member - Captain (WA) - Thursday, Aug 19, 2004 at 23:56
Your certainly on the right track Voxson!!! The front wheel that hasn't lost traction would be going at vehicle speed, so the front wheel that has lost traction would be going double speed.
However,that would also mean that the rear wheels would have to turn faster, but they cannot (assuming both rear wheels have traction). So, one of the rear wheels must also lose traction. Then one front and one rear wheel would be spinning at twice the opposite wheels speed! Basically identical, but in reverse, of what happens when you spin your wheels going uphill.
How do I know this? Easy, I cheated!!! I have a remote control 4WD and I simply tried all the combinations of simulating different things to work it out. I tired to figure it out in my mind but my head then started to spin!
Captain
FollowupID: 333471
Follow Up By: V8troopie - Friday, Aug 20, 2004 at 00:25
Hang on, I think I'm missing something here. If a wheel is skidding downhill, it surely is NOT turning at all, yes? Then, how can the opposite wheel spin at twice the rate of the stationary wheel? What's twice zero??
Please explain before I too have to go out and buy a remote control toy 4WD and get my head spinning :-)
Klaus
FollowupID: 333474
Follow Up By: Member - Captain (WA) - Friday, Aug 20, 2004 at 00:38
Hi V8troopie,
The wheel thats "stationary" is not actually stationary! Its still being driven at engine idle speed, but its turning slower than the speed gravity is dragging the vehicle downhill, so to an observer it looks like its stationary because its turning slower than rolling speed. This one was easy, did not have to grab the r/c 4WD to figure it out ;-)
If the engine was to stall and one front wheel (and by default, also one rear wheel) was stationary, the other front (and rear) wheel would turn at vehicle sliding speed.
Captain
FollowupID: 333476
Follow Up By: MrBitchi - Friday, Aug 20, 2004 at 08:01
If you look at a vehicle which loses traction in these circumstances you'll see what happens is the wheel that loses traction is actually driven in reverse by the action of the diff as the vehicle speed increases. First time I saw it (back in my Army days) thought I was seeing things 8--; but work it out , if the vehicle speed increase and one wheel has full traction and engine revs don't rise then the extra speed is fed to the wheel with no traction. The diff gears dictate it must spin backwards.
To quote my 10 year old, "My brain aches!!"
FollowupID: 333483
Follow Up By: Member - Gary W (VIC) - Friday, Aug 20, 2004 at 13:15
MrBitchi is correct in theory the wheel in the air going down hill will spin in reverse.
Gaz
FollowupID: 333529
Follow Up By: Member - Captain (WA) - Friday, Aug 20, 2004 at 15:40
Hmmm... not sure about that Gary.
If one wheel is in the air, drive can go to that wheel so it will spin forward at engine speed (providing one back wheel also loses traction). The front wheel on the ground will simply travel at vehicle speed (ie it will overspeed compared to driven speed, but still be going forward).
However, if both front wheels are on the deck, but one front loses traction, then the one with lost traction will turn "backwards" IF a) one rear wheel also loses traction AND b) how fast the vehicle now "slides" downhill compared to engine idle rpm. Note that backwards is a relative term here. The wheel is turning slower than ground speed (actually at engine idle rpm/gear speed), but is still travelling in the forward direction. This gives the illusion of turning backwards.
The whole question is actually very interesting. By playing around with my model 4WD, I have found that many of the above scenarios are true, it all depends on the relative overspeed of the vehicle sliding, whether a wheel is in the air or simply loses traction while on the deck and also what the rear wheels are doing (if both rear wheels have good traction, they dictate the speed of the drivetrain, then it further depends if a front wheel is in the air or both on the deck)
I have spent too much time on this already, but it really intrigued me (like when you get a song in your head and cannot stop it !!!). Ultimately there are so many different scenarios depending on what wheel has traction etc... that there is no right or wrong answer without imposing more conditions on what other wheels are doing.
Just hope your heads not spinning like mine over this ;-)
Captain
FollowupID: 333558
Follow Up By: Member - Gary W (VIC) - Friday, Aug 20, 2004 at 17:01
Yep you're right. The free wheel only goes backwards while the wheel with traction is going more that twice the speed than if all wheels had traction - this so long as both rear wheels have traction too.
The point is though - without braking (which changes everthing) and in a downhill situation the vehicle will let go and like be going faster than twice the fully tractioned speed and therefore the free wheel will be in reverse. That why I said "in theory" in practice the driver will likely brake and/or the the free wheel is unlikely to remain free for long. So I guess it would be relatively rare for the free wheel to be going reverse for long if at all. But we are theorising - or at least I was.
But I'm not sure I agree that the there needs to be one rear wheel in the air too. But I don't have a remote control car with me *grin*
Gaz
FollowupID: 333570
Reply By: duncs - Friday, Aug 20, 2004 at 18:20
Now all that has really confused me. I dont have a R/C 4x4 to play with (jealous again) and I'm not sure if Davoe does either but I stand by what I said right back at the start. I know this 'cause I've done it with and without difflocks.
In fact on one particularly steep and rocky downhill I had the air line drop off the airlocker. Now all the theories aside the old GQ fairly leapt down the hill. My pulse rate applied the inverse square law and I had to change underware when I got home.
Duncs
AnswerID: 73435
Reply By: SteveA - Friday, Aug 20, 2004 at 22:00
after reading all the replies my head hurts as well but after reading all about this in a number of 4b mags dont you put the foot on the accelerator if you loose traction on the way down the hill so that you still have control of steering (it hasn't happened to me yet!!! Not trying hard enough)
Steve
AnswerID: 73460
Follow Up By: Member - Gary W (VIC) - Monday, Aug 23, 2004 at 13:45
I can vouch for the 'accelerate to regain traction' trick. I was on a very muddy slide in my previous 4b (Jeep) with tyres that shouldn't have been anywhere near the place. Got into a slide with no control. Hit the pedal and regained traction. It saved my bacon. But wouldn't go looking for opportunities to try it unless you found a safe place.
Gaz
FollowupID: 333774
