Anderson Plug Termination
Submitted: Friday, Aug 20, 2004 at 20:36
mattieharding
Just wondering what type of tool do you use to terminate Anderson plugs? Do you crimps them, solder them or???
Reply By: Crackles - Friday, Aug 20, 2004 at 20:45
The 50 amp plug needs a 16mm crimping tool. Not sure what size the big one needs. Cheers Craig.............
73453
Reply By: Banjo - Friday, Aug 20, 2004 at 21:54
Great system the Andersons - such a sensible and simple design - I just soldered my terminals onto the cable - just warm them up over a gas flame, run some solder into them and then feed the pre-soldered wire into the hot terminals - blow em cool - its all over....slot them into the plastic receiver until they click home on
the springs....if you need to get them out again, just depress
the springs with a
small screw driver and wriggle the terminals back out.
73458
Follow Up By: Member - Cocka - Friday, Aug 20, 2004 at 22:52
Banjo is right, solder them in. But remove the terminals from the plastic housing first is what he is saying, plenty of flux & solder, once they have cooled they just press back into the housing & make sure the + and - terminals are in the correct sides.
Important to remember that the + terminal is live and not totally concealed so be careful that nothing gets to touch it and shorts out.
333602
Reply By: eerfree - Saturday, Aug 21, 2004 at 11:17
Anyone know if I can purchase an "Anderson" type socket that can be recessed into bumper bar (as can six pin sockets)?
eerfree
73480
Follow Up By: mattieharding - Saturday, Aug 21, 2004 at 12:26
MMM not to my knowledge, you could just screw them onto the bar if thats an option.
333624
Reply By: rock hoper - Saturday, Aug 21, 2004 at 15:08
if your in qld near gympie or
dalby .
drop into L.C. 4X4 and i will crimp them for you for free..
as the tool cost to much if you are only using it once or twice ....
some times i crimp then solder . depends on what it is used for....
e-mail : tuff4by@dodo.com.au
73501
