GU speedo stopped!
Submitted: Monday, Aug 23, 2004 at 13:44
ThreadID: 15763 Views:1924 Replies:2 FollowUps:3
Hi all,
Driving home yesterday and had to slow through a 60 zone and speedo was at 72kph so I kept slowing and thought hang on i'm at 1500 rpm!!!! The speedo stopped at 72kph. Then as I sped up past 72kph the needle moved up and it has not stopped there again. Did a search and didn't find anything is this a know issue?
TIA...Leroy
Reply By: Member - Roachie (SA) - Monday, Aug 23, 2004 at 14:12
G'day Leroy,
I'm assuming (cos you said "72") that it must be a TI model with digital readout on the speedo?
Sounds a bit weird and i can only assume it's one of gremlins that "electronics" cause which make me detest them so much.
Good luck
AnswerID: 73684
Follow Up By: Leroy - Monday, Aug 23, 2004 at 15:02
Hey Roachie,
No an ST with analog display but was reading approx. 72 kph.
Leroy
FollowupID: 333782
Reply By: Member - Kerry (VIC) - Monday, Aug 23, 2004 at 15:46
next time it happens give the dash a good BASH!!! that will sort it, this used to happen to my old car
AnswerID: 73692
Follow Up By: Leroy - Monday, Aug 23, 2004 at 16:19
I'll wait until it's out of warranty first!
Leroy
FollowupID: 333787
Follow Up By: Brian - Monday, Aug 23, 2004 at 19:17
Had a commadore that did this, all you needed to do was place your hand on the speedo the magnetic filed nocked it for you!
Brian
FollowupID: 333799
