Fold Down Shelf on Rear Door
Submitted: Saturday, Aug 28, 2004 at 22:52
Member - Ivan (ACT)
Guys,
I'm fitting up a fold down shelf on the rear
barn door of the Prado.
Got it all sussed except for how to hold it up when not in use...
I don't want something that I'll catch on, or that will protrude too much.
Thinking maybe some stretchy elastic on the upper corners, but that might stretch..
Any
bright ideas out there??
While you're at it, for those that have done it already, what did you use to suspend the shelf when in use? - I'm thinking some thin chain - but will need to fold inside the closed shelf so it's not swinging/rattling..
Think I'd like something lower profile, but don't want anything that will stretch - once again, any
bright ideas??
Reply By: Outnabout David (SA) - Saturday, Aug 28, 2004 at 23:07
Howdy there Ivan,
Good to here from you.
They tell me you are the meanest seargant at arms.
Anyway don't use the chain because it rattles. I have seen some made out of thin cable like they use on sail boats and then plastic coated. I am faily sure if you have a look around a good hardware
shop you will find some cupboard brackets that will do the job. Also same goes for the catches.
On my old Prado I had some catches that were brass with a couple of ball bearings in them with the other piece fitting snuggly in the middle.
Have a look on the yahoo group 'cos there used to be some pictures of a rear table on there. Nort sure if they are still there now.
Catchya on another trip.
74392
Follow Up By: Member - Ivan (ACT) - Sunday, Aug 29, 2004 at 08:55
Thanks Dave (Bam-a-lam ;-)))
334315
Reply By: Member - Fay D Away (Vic) - Saturday, Aug 28, 2004 at 23:15
Hi Ivan
I have the standard Britz camper type and works
well
Send us your email addy and i will post you some photo,s of the parts tommorrow (Sunday)
Bill
74393
Follow Up By: Member - Ivan (ACT) - Sunday, Aug 29, 2004 at 08:56
Thanks for that Bill
isanders at ozemail dot com dot au
334316
Reply By: Dave from Fraser Coast 4WD Club - Sunday, Aug 29, 2004 at 07:47
i tried chain and it drove me mad. I could hear it distinctly over all of the other rattles!
I went with venetian blind cord (stonger than you think)
I ended up ditching the table idea as it was in the way of the fridge slide when in use and the whole shooting match ended up being a PITA!
but good luck.
74408
Reply By: Member- Peter & Mrs Peter, Lez - Sunday, Aug 29, 2004 at 10:19
There is a thread on the Overlander
forum at the moment with photos. He used magnetic cupboard latches to hold it up when not in use.
Cheers Peter
74412
Follow Up By: Joe - Sunday, Aug 29, 2004 at 13:56
Hi Peter,
I'm interested in checking this out. Do you have the web adress for Overlander?
Joe
334328
Follow Up By: Utemad - Sunday, Aug 29, 2004 at 16:52
Overlander table
334334
Follow Up By: Member- Peter & Mrs Peter, Lez - Sunday, Aug 29, 2004 at 17:26
Thanks Utemad, Joe use that link and scroll down to Hefty Merv and click on his photo link.
334336
Reply By: Plugger - Sunday, Aug 29, 2004 at 17:03
Ivan - I made a table for the large
barn door on my GU. Keep it up when travelling with stretch elastic thingies that I got from a canvas maker. Used small wooden door knobs to hook them around. Also used chain to hold it when in use. To stop the rattle I covered it with heat shrink tubing. Cannot hear it all now. Table very useful and kept in the good books with SWMBO, for a little while at least Plugger
74433
Reply By: Crackles - Sunday, Aug 29, 2004 at 17:58
Gaday Ive. Try HD stainless steel leader wire used for fishing as a support. It has the eyes crimped on already. Depending on the tables weight a magnetic catch is fairly low profile, a window security latch if it's heavey or just some Valcro if it's light. Another option is spring loaded hinges that flip up when overcentre. A mate has recessed a thin nylon cutting board into his table which was pretty handy too.
Anyway it looks like a good excuse to head down to the hardwear store or boating
shop to look through the fittings.
Cheers Craig.............
1.2 m of snow on Mt Skene this weekend. Drove around 50 bogged cars in a Playdoe. O' what a feeling. ;)
74438
Follow Up By: Member - Ivan (ACT) - Sunday, Aug 29, 2004 at 20:02
Hi mate,
Thanks for that - the crimped eyes and steel leader are the go I think - got the rest sorted I think ;-)
So got you into a Playdoe!! - and in public too ;-)
334356
Reply By: Truckster (Vic) - Monday, Aug 30, 2004 at 10:36
[ View Image]
...this is the one that I had on my door..
Also have a look here, list of different types of locks.
74491
Reply By: Troopy Travellers (NSW) - Monday, Aug 30, 2004 at 19:52
I have a drop down shelf on the rear door of my troopy. I used S/S braided wire either side with a small hole drilled through the shelf, purchased from the S/S
shop ($3/m) Then I used a good quality square shaped barrel bolt which holds the shelf tightly closed. Simple!!!
Sparky
74559
Follow Up By: Andrew from TrekTable - Wednesday, Sep 01, 2004 at 22:31
Ivan,
Try 25mm webbing (like used on backpacks etc). It doesn't rattle or scratch and folds away flat between the shelf and door lining. Use shock cord loops to hold the table in the closed position.
Check out www.trektable.com.au for more hints.
link text
I can supply webbing and loops if you can't source them.
I'm after an 80 Series to develop prototype if anyone is willing and lives in
Brisbane.
334682
Reply By: Andrew from TrekTable - Thursday, Sep 02, 2004 at 12:41
Ivan,
Apologies to other
forum readers. Being a newby I did a 'Follow-Up' rather than 'Reply' so I'm resubmitting.
TrekTable link
Brisbane.
74879
