Help - Camry Headlight Problems
Submitted: Sunday, Aug 29, 2004 at 08:27
ThreadID: 15896 Views:2102 Replies:4 FollowUps:0
I have an 88 camry with intermittent headlight problems - every now and then the low beams dont work. high beams and park lights are fine. can anyone give me an idea what to look for?
cheerio, tim c
Reply By: motherhen - Sunday, Aug 29, 2004 at 10:48
Thinking, thinking - had same problem a few years ago with a cruiser - my auto electrician knew exactly what to replace - just can't recall what it was. Started out with a few seconds pause of darkness when dipping, after a while no lights at all on dip - were taking a load of strainer posts on ute plus trailer that night so our high beam were very high - had no choice but to dazzle the oncoming traffic. If this sounds like your problem, i'll think a bid harder
AnswerID: 74414
Reply By: Crocbit (NT) - Sunday, Aug 29, 2004 at 11:19
Hi ZTim,
OK, I am not familiar with that model, but assuming it has split power feeds to headlights (ie one fuse drives either left side or right side) the problem could only be the switch or relay where the battery is common.
Sometimes if the high beam is on for a long time the relay contacts can weld themselves. try tapping the relay when the problem occurs, same goes for the switch.
Otherwise get a wiring diagram for the car and check with a test lamp.
AnswerID: 74415
Reply By: Member - Jiarna (SA) - Sunday, Aug 29, 2004 at 11:43
I believe that these lights work by switching the earth connection, so check the earth connections on your relays. I had a similar problem on a Falcon, and fixed it by crimping up the loose earth connections.
AnswerID: 74416
Reply By: Bruiser - Sunday, Aug 29, 2004 at 17:24
had this problem with mine get another headlight switch apparently its a common problem most unnerving when the lighs go out when you most need them
AnswerID: 74434
