Getting decals off
Submitted: Sunday, Aug 29, 2004 at 17:41
PerthGQ
Hi all,
The wagon has some of those aftermarket decals down the side that are supposed to make it look better (not)!?
I've put up with them for ages but time has come to get rid of them. Can anyone recommend a tried and proven way to get them off without damaging the paintwork. I knew a bloke some 20 years ago that had a homebrew remedy that he would paint over them and would release the goo from underneath and they would just lift off. Seen it first hand when he did a sandman van and they came off clean as whistle, but he would never let on what the concoction was. As much as I hate the stickers, I sure dont want to mess-up the duco. Appreciate any tips.
Thanks in advance..Keith
Reply By: alister - Sunday, Aug 29, 2004 at 17:49
Heat them with a hair dryer. That will soften the glue without damaging the paint. Peel the corner with your thumbnail and keep the heat ahead as you slowly and gently peel it off.
74436
Follow Up By: Member - Roachie (SA) - Sunday, Aug 29, 2004 at 19:49
Alister is right on the money mate,
I had the same situation in 1995 when I bought a 1993 GQ Patrol. It was white and had these wuzzy wavy stripes down the side. Left em on for about 2 years b4 i summoned the guts to hit em with the hairdryer. Came off real easy once I started.
However, just to nit pick, if I may......they aren't really "decals" as far as the strict sense of the word goes (AFAIK). They are actually "stickers". IMHO decals are those that you soak in
water and slide off the backing paper, onto the job. I will stand corrected though.
334354
Follow Up By: Lone Wolf - Sunday, Aug 29, 2004 at 22:54
"IMHO decals are those that you soak in
water and slide off the backing paper, onto the job. I will stand corrected though."
Yep......
Buy a model plane, stick it all together, then get the saucer of..... wait for it......"luke warm water"
Drop the bloody thing in the
water, watch it curl one way, then the other. Pick it up with your dry fingertip, watch it slide onto the floor, pick it up again, join the 2 halves together, stick it on the wing, watch it go all wrinkly when it dries. Peel it off, find some other stickers from other models.........Whoa!!! my Spitfire is now sporting a Swastika!!!!
Wolfie
334376
Follow Up By: Member - Russell B (SA) - Monday, Aug 30, 2004 at 20:37
Noun 1. decal - a design fixed to some surface or a paper bearing the design to be transferred to the surface
decalcomania
pattern, design, figure - a decorative or artistic work; "the coach had a design on the doors"
transfer paper - a paper that is coated with a preparation for transferring a design to another surface
2. decal - the art of transfering designs from specially prepared paper to a wood or glass or metal surface
decalcomania
artistic creation, artistic production, art - the creation of beautiful or significant things; "art does not need to be innovative to be good"; "I was never any good at art"; "he said that architecture is the art of wasting space beautifully"
Geez we can be picky sometimes.
Russell ;-)
334465
Reply By: navaraman - Sunday, Aug 29, 2004 at 17:56
If the decals have been on for a long time the paint may be a different shade underneath. A mate of
mine bought an old work van off me and I removed the signwriting, you can still read what it said if you look carefully though. The paint under the decals doesn't age/oxidise/fade/whatever as much as the exposed paint.
A couple of cut and polishes might remove it..
74437
Reply By: Banjo - Sunday, Aug 29, 2004 at 18:02
Yep - hair dryer is the go, BUT as Alister says, go very slow on the peeling and keep the pull as flat as you can (not 90 degs to the paint surface !). Also, eucalyptus oil is great for some labels (that's a fierce solvent in there that the Koalas eat) but it may not get through synthetic decals. Idea is to give them a good soak, then peel. If trying this, do an oil/paint test somewhere safe first !
74439
Reply By: Lone Wolf - Sunday, Aug 29, 2004 at 18:07
When I had the shlts up with this
forum, the EO sticker on the Honda came off REAL easy!! LOL!!
74440
Follow Up By: schevchenko - Sunday, Aug 29, 2004 at 21:22
LOL lone wolf
you can cut and polish the gunk left behind after you peel it with dryer. I used 'nu-finish' me thinks with a rag and really got stuck into it with the old thumb. beaudiful results
334365
Follow Up By: Lone Wolf - Sunday, Aug 29, 2004 at 22:49
.......... too scared to ask David & Michelle for a new one........
334375
Reply By: PerthGQ - Sunday, Aug 29, 2004 at 21:24
Again the
forum comes through. Many thanks to you all.
The hair dryer will get a pounding next weekend and hopefully the GQ will get naked!
Regards..Keith
74459
Follow Up By: Shaker - Sunday, Aug 29, 2004 at 22:22
If they are 'after market' decals, be very careful, because they are cut & shaped with a craft knife & quite often the cuts go deep into the paintwork. Sometimes they seal the ends with clear nail polish for this reason. If this is not the case & they were a 'decal kit' (unlikely) you can get the residual adhesive off with prepsol.
BTW .... hope, beyond hope that the decals were on original paintwork, otherwise you stand a greater than even chance of removing paint with the decals!
334373
Reply By: myfourby - Monday, Aug 30, 2004 at 22:28
I have also been through this saga!
A mate of
mine cuts stickers for cars for a living and made some new ones up to replace my old ones (I was originally going to leave it bare - but after I removed them - the car looked naked and boring - so new ones went on!)
Anyway - the safest and best way to remove the stickers accoring to my mate is to pour hot
water down the stickers and gradually peal them off. The hot
water I'm guessing would do the same type of job as a hair drier - but -
water seams to me to be a little safer for the paintwork (keep thinking of those paint stripper guns when I hear of people using hair dryers!). Anyway - hot
water worked a treat for me.
-Myfourby
74595
Reply By: PerthGQ - Tuesday, Aug 31, 2004 at 22:09
Boy, it's sure amazing how much interest them stcky picture thingys can muster up!!
I'll be giving it a go on the weekend with more than fingers crossed.
Thanks again to all.
Keith
74755
