clear coat pealing
Submitted: Monday, Aug 30, 2004 at 22:35
ThreadID: 15937 Views:3639 Replies:8 FollowUps:5
Help!
I've got a patch on my bonnet that is missing the shinny clear coat paint. The problem I have is that each time the car gets washed the patch peals away and is getting larger and larger. Dirt ctaches under the edges of the clear coat which makes the problem worse.
How do I fix/patch/prevent the patch from getting larger?
-Myfourby
Reply By: bruce.h (WA) - Monday, Aug 30, 2004 at 22:45
unfortunatly your only option is to strip & respray the bonnet
AnswerID: 74596
Reply By: lazylcd - Tuesday, Aug 31, 2004 at 01:24
Unfortunatly i have the same problem on the bonnet of my gq, started as a lil blister and has grown and grown.
i belive it was someones great idea to spray the hole car in it, basially like contact for your car, i must admit it used to look pretty good, but now ive noticed it just below the windscreen too, starting to spread, i havent spoken to a pannel beater yet, basically cause in scared of the answer he will give me :o(
if any 1 has any idea of who the hell invented this product id love to give them a piece of my mind, but in the mean time i guess i got to live with it.
Lazy
AnswerID: 74603
Follow Up By: Rosco - Bris. - Tuesday, Aug 31, 2004 at 07:06
Lazy
That's the clear coat they spray over metallic paint. Sorry mate but it's standard procedure and what gives the whole car the shine.
FollowupID: 334504
Reply By: Eric from Cape York Connections - Tuesday, Aug 31, 2004 at 06:38
I have the same problem with my hair.
Every time I wash my head the shinny grey coating dissapears a bit more.
The only good thing is I dont have the problem with the dirt.
I hope we both get an answer to our problems.
All the best
Eric
www.capeyorkconnections.com.au
AnswerID: 74609
Reply By: Flash - Tuesday, Aug 31, 2004 at 08:24
That's why I won't own a metallic.
The only sure fix is a complete respray. $$$$$
AnswerID: 74619
Follow Up By: Michael - Tuesday, Aug 31, 2004 at 13:45
What happened to the 'Good 'ol Days',,? horse and cart. If the horse broke down, At least you could eat it!!!!!!
FollowupID: 334541
Reply By: Wheelerdog - Tuesday, Aug 31, 2004 at 12:20
are the cars listed above silver by any chance.
AnswerID: 74653
Follow Up By: myfourby - Tuesday, Aug 31, 2004 at 20:06
Nope - white 95 hilux
FollowupID: 334591
Follow Up By: lazylcd - Wednesday, Sep 01, 2004 at 23:57
nope two toned blue on grey 89 patrol
FollowupID: 334697
Reply By: NissanofOld - Tuesday, Aug 31, 2004 at 18:35
I had a silver MQ for over 12 years with no problems at all. When I sold it, from a few metres away you couldn't pick even one of the fine scratches in the paint surface. The clear coat that is overlaid on all metallic paint (and others for that matter) and is not a problem unless something has gone wrong, or it's been done later and not correctly prepped.
If this is happening, then as another suggested, the only solution is a complete re-spray. Has yours by any chance been resprayed or has something got onto the surface at some time?
AnswerID: 74709
Follow Up By: myfourby - Tuesday, Aug 31, 2004 at 20:10
I bought the vehicle 2nd hand - so it may have been resprayed - but it doesn't appear as though it has been. I centainly haven't resprayed it or done anything to it.
A small patch just appeared - possible after a particualry aggresive session with a high pressure water spray - and now its started a chain reaction that i can't stop! The patch getting bigger and bigger! :(
FollowupID: 334592
Reply By: sails - Tuesday, Aug 31, 2004 at 22:01
Hi Myfourby,
sounds like they got you with the "shiny object syndrome".. I was getting some paint from my local shop a couple of weeks ago to redo a bonnet and tail gate and the man told me that nearly all paint these days is done as clear over base, not only the metallics. A good way to make a tired paint job shine again.
Obviously there is a an adhesion problem. Check to see if the exposed white paint has any indications of sanding or scuffing to get a key for recoating. If there isnt any (and they can be really fine, like from a grey scotch brite) you might be able to peel it all off, and be left with the original white enamel.
With the clears you could try patching it, but that means having the compressor, spray gun, paint and thinners etc, and its not cheap if you are not already set up, or have a mate with the gear. You could patch it with acrylic laquer clear, and cut it back to level it, but its a job for a pro to do it right. You could even try brushing some clears over the patch( depending how big it is) and blocking it down to level it with the old clears, but its all fiddly.
I doubt that you would find a panel shop that would not sand it back and re do it .
good luck
Sails
AnswerID: 74754
Reply By: Crazie - Wednesday, Sep 01, 2004 at 08:53
I had a 300zx that this happended to, the panel beater suggested it was possum pee. I went home and discovered I was parking under a power line where possums regularly traveled.....
AnswerID: 74775
