FollowupID: 335003 Submitted:
Sunday, Sep 05, 2004 at 18:01
Utemad posted:
Drivesafe,
30,000 crimps/yr!!! Remind me never to shake your hand. I don't want mine broken from your crimp muscles LOL.
I also use Lanolin on my car. I use it everywhere. From on bolt threads to general rust proofing and giving extra life to electric motors.
I have only had two solder joints fail in my vehicles (that I know of). One was from mechanical stress. It was not a good joint to start with as it was in a bugger of a spot up under the dash and it snapped as solder joints are rigid unlike the rest of the cable.
The other was as you have mentioned, from corrosion. Although it was on a boat trailer. It was an untinned section of the copper cable that snapped right in line with the edge of the insulation.
In the past I have lanolinned some joints but not all (generally because I cannot find my lanolin bottle). It is an excellent idea to put a squirt or two in your trailer connector (trailer and vehicle) as there is nothing more annoying then opening someones connector to see why a connection isn't working and finding it all corroded with rusty screws.
I agree that those ratchet crimpers are the way to go. I have a set and they are great. Although my favourite are the plier crimped terminals. The ones that fall off when you touch them LOL.
I borrowed from an old workplace those big (can't remember the name) crimpers for the battery cables with the rotating jaws to get the right size crimper. Look like bolt cutters. I used them for my dual battery setup as I have 32mm square cable.
What I do find interesting is that the corroded solder joint is something I discovered while playing with my vehicle and was never warned about it by the more learned guys where I used to work (don't do that stuff anymore. Chucked it all in to go back to uni).
Thanks for the reminder about corroded solder joints. I used to solder thinking I was being good but now we know there is more to it than that.
Utemad
