AnswerID: 75306 Submitted: Monday, Sep 06, 2004 at 11:28
Member - Captain (WA)
replied:
Hi Simon,
I had a 80 series 1HZ for many years and did a fair bit of towing in that time (I have a 1.6T offroad van). When I got my GU, I couldn't believe how much difference it makes having sufficient power when towing - 274Nm vs 420Nm (Dtronic). I know you are looking at only Toyota, either turbo or non-turbo - not starting a GU/Toyota thread, just looking purely at torque difference between two vehicles.
After experiencing having good power/torque for towing, I could never go back to a 1HZ without a turbo. Before I had the GU, I was happy with the 1HZ for towing, but it was S...L...O...W... as soon as anything but level ground was encountered. I even put on extractors and a 2 1/2" system and while it made a noticeable difference, it cannot even begin to compare to the torque of the GU.
While the 1HZ non-turbo will lug a heavy load all day and have no problems at all, it is simply nowhere near as relaxed as towing with a GU/Toyota turbo and having 420Nm to make hills simply disappear. Hills that took 3rd in the 80 series can be done in 5th in the GU, there is that much difference!
At the end of the day, either vehicle will get you to where you are going and you could live with the 1HZ, but having a turbo makes it simply that much more relaxing.
Captain
 Click Image to Enlarge |
| Its not what you drive, but how you drive it!
Reply 3 of 5
