Barrett 950 'Whip' antenna
Submitted: Monday, Sep 06, 2004 at 20:55
Steve
Wonder if anyone has a beaut idea of where to carry the antenna of this little wonder ..I usually leave it in the shed between trips but would rather carry it in the rig ...(Toyo Station Wagon 80 series) with a simple carrier inside the cabin...
Reply By: Voxson (Adelaide) - Monday, Sep 06, 2004 at 21:33
I slide
mine down the side of the seats along the door line through the c/barrier...
But can be bent if not careful... There is nowhere to carry the long ones safely but you can always keep the smaller version in the car...
75408
Reply By: Member - Bernard - Monday, Sep 06, 2004 at 21:35
Steve --
I have a very long antenna which I carry all the time in the Pajero. I carry it on the passenger side tight up to the grab handles and utilising the cargo barrier. Basically it extends from a position in line with the front passenger's head to almost back to the tailgate door.
I wrapped some self-adhesive Velcro around
the tip with a corresponding patch stuck on the roof lining to the left of the passenger's head ... this keeps
the tip in place and up tight against the roof. Another self-adhesive strip of Velcro was wrapped just above the antenna base and a corresponding piece fixed to the top of the cargo barrier ... this keeps the "fat end" tightly in position. I slide the antenna in over the top of the cargo barrier, fix
the tip to its Velcro patch at the front, then fix the base (or lower part) to its patch on the cargo barrier.
To stop it flexing and rattling, I use about a five-inch strip (old measure) of double-sided Velcro to strap it tight to the grab handle over the rear passenger door.
I hope my description is understandable ... sounds messy and complicated when I read over it, but it isn't really.
Bernard
75409
Follow Up By: Steve - Monday, Sep 06, 2004 at 21:41
Almost too obvious ...strap it up to the grab handles with ...VELCRO..!! will be off to get some 'manana'. Also Voxson mentioned a 'small' antenna ??? am I missing something...mines about 2 metres !! and it sit on top of the auto tune
grey gizmo..
Thanks..
steve
335148
Follow Up By: Voxson (Adelaide) - Monday, Sep 06, 2004 at 21:52
There is a smaller version about 1200 tall.. Check your local comms store...
335149
Follow Up By: Member - Bernard - Monday, Sep 06, 2004 at 21:52
Steve --
Appreciate your comment about "Almost too obvious ..." but I was quite a while in getting my poor old brain to consider the answer. I tried all sorts of things -- including buying a beaut (but expensive) slimline protective bag or holder for a fishing rod ... spent 10 times as long trying to make that work as it did to set up my final solution!! Some days I shouldn't be allowed out of bed without my pill.
Bernard
335151
Follow Up By: madcow - Monday, Sep 06, 2004 at 21:56
I also carry my fishing rod whilst intransit the same way. Cable tie it to the grab handles and less likely to get damaged up there.
Cheers Dave
335152
Reply By: Member - Captain (WA) - Monday, Sep 06, 2004 at 22:15
Hi Steve,
In my GU, I fix it to the cargo barrier in an arc. If you look very closely on my 2nd rig pic, you can "just" make it out near the fire extingusher on the cargo barrier.
On my previous 80 series, I cable-tied a short section of black 13mmm poly pipe (retic pipe) above the grab handles on the passenger side and slid it in from the cargo barrier along the handrails. Very similair idea to the velcro.
Captain
75419
Reply By: Wisey (NSW) - Tuesday, Sep 07, 2004 at 18:59
Go to gardening section of a good hardwhare and get some velcro for tying trees up, cut to length, hooks on one side, sticks to other, PRESTO.
Good for cables, hoses, rods, ariels, kids, missus, not sticky totally reusable... you get the pic... ;))))))
75554
Follow Up By: Steve - Wednesday, Sep 08, 2004 at 23:06
Thanks to all for the ideas... been a busy boy chasing up all those ideas...as for the velcro straps...are they hard to find ?? spent today and got three littlies ...hope they do the trick ...
steve
335536
Reply By: Wisey (NSW) - Thursday, Sep 09, 2004 at 17:17
Hi Steve,
ONE WRAP (tm), dist by Multicrop, 926 Mtn Hwy, Bayswater VIC.
2 X 1.5m (12mm) rolls
Major hardwares or nursery should have this or adjustable rubber tree ties.
75852
