Jackeroo indicators
Submitted: Monday, Sep 06, 2004 at 21:27
The Jack
I have a '98 Holden Jackeroo SE, recently the indicators have started to only work intermitently. They stop and start (mostly stop) even at one
intersection. Anyone who knows how to fix this, before I have to pay someone else. Thanks, The Jack
Reply By: Member - Sand Man (SA) - Monday, Sep 06, 2004 at 21:33
The Jack,
Check each of your idicator globes. If one is blown it will affect the operation of the whole system. If globes are OK then you probably have a crook relay unit.
75407
Reply By: Savvas - Monday, Sep 06, 2004 at 22:15
Most likely the relay. It is located above the fuse box behind the driver side kick panel.
Do your
hazard lights work ok?
75418
Reply By: The Jack - Monday, Sep 06, 2004 at 22:18
Thanks Sandman (SA) I checked by rear indicators, I could'nt check the front because I can't work out how to get the damn things out. I found no blown globes in the rear but the indicators now work, might have been a loose or wet connection.
Thanks again.
The Jack
75420
Reply By: Muddy 'doe (SA) - Monday, Sep 06, 2004 at 22:40
You say that the indicators only work intermittantly and that they stop and start.
I hate to point out the bleeding obvious to you but.......... aren't they supposed to do that???
Sorry, it is getting late...lol
Muddy 'doe
75423
Follow Up By: Savvas - Monday, Sep 06, 2004 at 23:01
Muddy ... I resisted that one, but I knew someone would catch on to it.
"Hey dear, are the blinkers working?"
"Yes they are, no they're not, yes they are, no they're not ...."
LOL
335169
Reply By: Tim - Tuesday, Sep 07, 2004 at 09:42
There is also a 2nd relay for the rear lights at the back somwhere. Never found it myself but put your blinkers on and follow the noise.
Tim
75468
