Fuel Tank Warning light on 80Series
Submitted: Thursday, Sep 09, 2004 at 16:14
ThreadID: 16167 Views:8341 Replies:7 FollowUps:3
Fuel Tank Warning light has turn on and I don't kwon what it means. The manual say to contract Toyota. Any idea would be great.
Reply By: Member - Jeff M (WA) - Thursday, Sep 09, 2004 at 16:52
Means you probally have water in your fuel system. try changing the fuel filter and bleeding the lines.
AnswerID: 75847
Reply By: GO_OFFROAD - Thursday, Sep 09, 2004 at 16:53
At a wild guess, Id say contact toyota ;-)
But which light is it, what color is it, and what does your book say it does?
AnswerID: 75849
Reply By: Kiwi Ray - Thursday, Sep 09, 2004 at 18:37
Hi Matho
The square orange light next to the fuel gauge indicates approx 10 litres of fuel remaining
The fuel light that looks like a radiator is from the fuel filter and indicates that there is water in the fuel filter and needs draining.
There is a drain tap on the bottom of the filter
Ray
AnswerID: 75860
Follow Up By: Matho - Friday, Sep 10, 2004 at 09:33
It's not the low fuel light i'm talking about. The Light says -Fuel Tank- and is orange in colour
FollowupID: 335744
Reply By: Member - DOZER- Thursday, Sep 09, 2004 at 20:50
Matho
If you own a petrol cruiser, it means there is a problem with the tank level controls or fuel pump over...to get rid of the warning, pull the wire off the ecu, situated pass rear quarter panel. If it comes back straight away, it is most probably telling you the fuel transfer pump is RS.
AnswerID: 75873
Reply By: tour boy - Friday, Sep 10, 2004 at 08:16
I remember once when I had the battery disconected for a lengthy time that when it was reconected the fuel light wouldn't go off ( full tank) Toyota told me to disconect the battery again for a couple of seconds and then re connect.
Problem solved.
AnswerID: 75904
Reply By: Member - DOZER- Saturday, Sep 11, 2004 at 18:24
Let us know what you find.
AnswerID: 76044
Follow Up By: Matho - Monday, Sep 13, 2004 at 12:07
G'day Dozer,
Will let you know whats wrong with it on Thursday. It's booked in then....
I don't think it will be that much of an issue, probably just a loose wire.
P.S you seem to be a 80 series Guru. I read all you replies with interest.
Cheers Mate
FollowupID: 335983
Reply By: jonsal - Saturday, Sep 11, 2004 at 21:09
Hi Matho, used to own an 80 series petrol. (Great truck, now have a deisel.) Had trouble with fuel warning light too. Turned out we couldn't access our sub-fuel tank to transfer to main tank. Mr Toyota drained both tanks and fitted new pump and sensors. All were a both dirty, and as they are super sensitive, set off the warning light. Wasn't a cheap solution but it had to be done. We are not mechanically minded, that's why we didn't tackle it ourselves. Good luck. John and Sally.
AnswerID: 76053
Follow Up By: Matho - Monday, Sep 13, 2004 at 12:09
Thanks for your reply. I don't think it's the sub tank, because I ain't got one lol. She a duel fuel Cruiser. LPG and ULP
FollowupID: 335984
