Maintenance Logs - Electronic Anyone?
Submitted: Saturday, Sep 11, 2004 at 09:23
Wazza (Vic)
As the 80 series is a long term vehicle for me, I am making up an Excel spreadsheet to keep track of all my lubes and
services (do most of them all myself). Does anyone have extras to add to my list. I have only just started, so it is not extensive yet, just things I thought of at work this morning while I have a few spare minutes. It is just to keep track of things. Could do it in a book, but though I would have a go in Excel.
Engine Oil
Engine Oil Filter
Air Filter
Fuel Filter
Front Diff Oil
Rear Diff Oil
Gearbox oil
Transfer Oil
Coolant
Brake Fluid
Power Steering Fluid
Front Wheel Bearings
Rear Wheel Bearings
Birfields Regrease
Front Pads
Rear Pads
Heater Hoses
Radiator Hoses
Injectors
Fuel Pump
Column headings are:
Item | Brand/Type | Date | KM | Cost | How Long ago | KM ago | Comments
When finished, I can email out a copy if anyone wants it. Or, if someone has a bling spreadsheet already setup ,they could email to me ;-)
Regards,
Wazza.
Reply By: Member Eric - Saturday, Sep 11, 2004 at 10:37
I found the front axle seals to be replaced every 50,000 kms , change diff oil and repack cv's is a must on the 80 series , also found front axle replacement is a must at around 250,000 kms , ( only on a constant 4x4 anyway )
76019
Follow Up By: Wazza (Vic) - Saturday, Sep 11, 2004 at 10:51
Yeah, I am getting up to 235,000k at the moment. It is going in to get the fuel pump leak fixed in a few weeks. Have bought the mrs a car which I can use for a daily run around, which I am hoping will help the 80 live longer (no more short trips, etc). Keep the 80 for trips only and update the wifes car is the plan.
Would like to make it to the High Country Trip as
well Eric, but am offshore until that first week in October. Oh
well, maybe next time. I have a couple of mates from work coming down from
Gold Coast on the 13th-17th Octoberso we are heading up there then, just planning it now. Will be interested in a good trip report from yourself and the others when you get back !
Wazza
335850
Follow Up By: Member - Jack - Saturday, Sep 11, 2004 at 12:44
Hi Eric:
My 80 Series has just clocked up 250K. What do I need to look for in replacing the front axle? I have just had the leaking steering box overhauled, new wheel bearings and seals etc on the front, and my usually reliable mechanic did not mention any problems. He is generally spot on, but I can ask him to take a look next service if I can let him know what to look for.
My 80 Series is also a long term proposition, now that I have managed to get a lot of "goodies" on it (rear wheel carrier, roof rack, steel bull bar, radios, overhead console , etc....). Gotta love eBay : )
Jack
335857
Follow Up By: Member Eric - Saturday, Sep 11, 2004 at 13:25
When you remove your front axles , look at the spline that goes into the diff , If there is no flat section between splines , then its time to say goodbye , I should take photos of these things to make it easier . Basicly if the top section of the spline is a tee pee shape that can cut you , is what you need to look for . if there RS dont stress , there very cheap at Don Kytes , around $200 each ,
mine had Gen toyota stickers on them , so I dont know what the go there is .
335862
Reply By: dirt-teaser - Saturday, Sep 11, 2004 at 15:12
I'm in for a copy when finished.
monterichon at yahoo dot com
76035
Reply By: theratt - Saturday, Sep 11, 2004 at 21:19
ill have a copy when your finnished good idea
theratt@optusnet.com.au
76054
Reply By: Michael - Saturday, Sep 11, 2004 at 22:20
No mention of the polishing of the triple chrome plated dust caps!!!!!
76067
Reply By: Wazza (Vic) - Sunday, Sep 12, 2004 at 02:37
I will email a copy of this in about a months time. I am currently offshore and want to get home and go through the service book and my receipts to see if there is anything else I can add. Members can PM me their email address if they don't want to post it..
wazza.
76075
Follow Up By: Trevor - Sunday, Sep 12, 2004 at 05:30
Wazza,
I can send you a copy of the one I use.
You are quite welcome to change it to suit your own needs.
How do I get in contact with you?
Unfortunately I'm a bit slow and I don't know what "PM" means.
Trev
335897
Follow Up By: Wazza (Vic) - Sunday, Sep 12, 2004 at 05:42
Thanks Trev, that'd be great. PM is just personal message, which comes up when you hit the "send member msg" buttton.
My email address is wazzagray [at] yahoo dot co dot uk
replace the [at] with @ and dot with .
335898
Reply By: Member - DOZER- Sunday, Sep 12, 2004 at 19:59
As b4, front diff seals, c/v's, axles, then maybe shox, springs, tyres, scheduled
services to tappets, exhaust, and lastly, fuel - where bought,kms travelled,litres tken, etc.
76120
