80 Series Timing Belt Tensioner
Submitted: Sunday, Sep 12, 2004 at 14:59
Stan
Can anyone give me an idea on what a Timing Belt tensioner sounds like when its on the way out. I have a 97 model diesel cruiser (1HZ) with about 140000 klms on the clock. I have a noise that sounds almost like a loose belt vibrating, and it increases with the increase in Revs. All other belts are fine, and its not a lifter kind of noise. I have heard that these tensioners can be a problem on this engine. Is this true.
Reply By: Goran - Sunday, Sep 12, 2004 at 18:15
Change it. They can be a problem. I assume you have changed the timing belt at 100.000 , right?. Way to check it is to pull timing belt off and check the tensioner for play. If in doubt change it anyway they are not expensive. If you let it fail , damage alone will be enough to make you cry.
76111
Reply By: Member - DOZER- Sunday, Sep 12, 2004 at 19:48
Take off the timing cover and put a screwdriver to your ear, listen to each part of the motor. (be careful not to slip) usually this brg is good for 2 belt changes.
U may find it is the
water pump or similar.
76119
Reply By: Member- Rox - Sunday, Sep 12, 2004 at 23:39
If its your
water pump Make sure that you undo the cam nut with the belt on. I just changed
mine (WP) (have all ready changed Timing belt 2 months ago) (no problems) but when undoing my cam cog it went backwards and bent some valves ($2614 later).
76141
Reply By: Coops (Pilbara) - Monday, Sep 13, 2004 at 10:44
I had a noise that I thought was the belt tensioner once and it turned out to be shot wheel bearings. Not saying this is the case but give it some thought cos you don't want to be seizing your bearings.
76169
