Tuning a Navara
Submitted: Monday, Sep 13, 2004 at 19:23
otech
First time on this
forum - looks very good and informative so hopefully I can get a quick hand.
Just bought a 1990 Nissan Navar with a 2.4L carbie motor.
Got it serviced but I reckon it runs worse after the service. Uses a whole heap of fuel - 300km to a
tank.
Is there a fuel mixture screw for these things (not a mechanic but can normally figure it out - cant see it at all) or is there a good book to get?
Any help is appreciated.
Reply By: Brew69(SA) - Monday, Sep 13, 2004 at 20:02
i would be straight back to the mechanic............worse than V8 economy.
76231
Reply By: Moz - Monday, Sep 13, 2004 at 20:14
G'day otech,
If there is a mixture screw it will only adjust your mixture at idle which
will not affect your consumption that much.
However I would be trying to check the fuel level in the bowl. This could be
a bit tricky and may need a manual to give you the procedure.
And check other things like ignition timing, cam timing and any air leaks around
carby and manifold.
Lots of luck.
Moz
76233
Reply By: navaraman - Monday, Sep 13, 2004 at 20:18
Haynes do a manual for the D21, D22 petrol Navaras, saw one in Repco on satrday. Not the diesel unfortunately.
76234
Reply By: otech - Monday, Sep 13, 2004 at 23:37
navaraman - just a quick question, can you recommend a good place for spare parts and service (hopefully your in SA)
I do a lot of travelling for work, so if not in SA please still provide details so i can grab when there.
Moz -thanks for that. Have checked timing plugs leads and for any leaks. Not the 'bowl'. Not really sure how. Will get manual for that.
Cheers for everyones help!
76272
Follow Up By: navaraman - Tuesday, Sep 14, 2004 at 08:15
I do the oil/filter changes etc myself but every 20000kms get it serviced properly to do the things I can't/won't try. I ve been using Rod Prime at Lonsdale, he's been recommended to me by several 4by drivers.
336076
Follow Up By: otech - Tuesday, Sep 14, 2004 at 12:48
Whats he charge for a normal service? (Just as an idea)
Would you give him at least a 9 out of 10?
336111
Follow Up By: navaraman - Tuesday, Sep 14, 2004 at 19:13
Just dug out my last invoice for a service. I had the gearbox, transfer case and both diffs oils changed
Service and labour $165
Various oils, fuel additive, indicator globe, EPA levy etc just undr $100
Total cost $287.
They picked up leaks at rear axle seal, worn brake drum, front bearing due to be repacked etc. and other items that they recommended doing at a later date that I hadn't noticed so all up I was very happy with the service
336172
