alko suspension tyre pressure
Submitted: Wednesday, Sep 15, 2004 at 11:52
boogum
Have a second hand Simon Heard camper trailer with alko
suspension; heading to
Flinders Ranges on the weekend (from Western Victoria). First big trip, 2 weeks in total.
Rawnsley Park, Chambers Gorge and
Arkaroola etc. Maybe shoot down to
Port Lincoln for a few days on the way home. Me, wife and 4 children.
The plate on the trailer says 50 kpa cold for tyre pressure. This is approx 10 psi. I am assuming this is the go, it just seems very low. Local tyre man very reluctant to only put 10 psi in tyres.
Anyone with experience or advice. Thanks.
Reply By: Truckster (Vic) - Wednesday, Sep 15, 2004 at 11:57
10 psi is stupidly low.
You should go with what the tires themselves recommend.
Call Simon Heard
http://www.simonheardcanvas.com.au/
76465
Follow Up By: boogum - Thursday, Sep 16, 2004 at 21:40
Thank you everyone for the comments and advice.
Simon Heard says 35 psi and the trailer manufacturer says 40 psi.
However they tell me the idea is to put a amount of air in the tyres to minimise the bounce (loaded trailer weight also a factor)
Me thinks 25 psi might be a good start.
See you in the Flinders, hopefully I'll be in one piece.
Boogum.
336480
Reply By: Vince NSW - Wednesday, Sep 15, 2004 at 11:58
There is someone else out there with a Simon Heard. Ours is 4 years old and has clocked up 25,000 km of dirt roads. Looks very second hand at the moment as all the paint is stripped from the front by rocks.
The 10 psi is very low, I run 22 on the dirt & 25 on the black top. Never had a flat (touch wood) on the trailer.
Vince
76466
Reply By: flappan - Wednesday, Sep 15, 2004 at 12:19
Nup . . . to low.
I also have a SH , CT.
Mine has identical
wheels and tyres (BFG AT's) as my Patrol.
I run only a couple of psi less then the Vehicle tyres.
76468
Reply By: DaveNJude - Wednesday, Sep 15, 2004 at 12:50
Try this simple formula:
Divide max tyre pressure by max load rating then multiply the result by the actual load per tyre
You may have to look up your tyre specs on the net but it usually on the tyre. I am guessing you know the gross weight of the trailer (yeah right!)
It tends to give a result that is about 3psi too high.
Clear as mud eh?
76471
Reply By: Banjo (SA) - Wednesday, Sep 15, 2004 at 13:35
IMO, 10 psi is possible for a light trailer in soft sand - but for general use, that has to be an error......as they others have said, 25 psi would be good for starters on a light trailer........see the tyre maker's specs if possible too.
76478
Reply By: Baz (NSW) - Wednesday, Sep 15, 2004 at 15:11
IMHO i think they left the 1 off, me i put 24psi in my bike trailer and 30psi in my camper, i have a Redback camper very similar to the Simonheard.
Baz.
76491
Reply By: 1 Mark - Thursday, Sep 16, 2004 at 19:25
If you can get your hands on September 2003 addition of Aust 4x4 (issue 236) and have a look at the parting pic. Guess what type of
suspension failed on this camper trailer? It was ALKO . I will never again own this type of
suspension and I would strongly recommend you thoruoghly try and check your
suspension as this one snapped where you cannot see.
76680
Follow Up By: govo - Thursday, Sep 16, 2004 at 23:08
I own a
dingo camper that i purchased new in 1996,it has done over 200,000 kms on all types of terrian..did a trip up north with 4 other campers,3 had top of the range suspensions( coils&shocks,leaf & shocks) and all 3 failed over the bad corragations only one made it home without something breaking but had a bent axle...my alko
suspension on the ol cheap
Dingo had stone chips..very happy traveller
336494
