What's that thingy
Submitted: Thursday, Sep 16, 2004 at 00:17
Member - Cocka
At the rear of the '02 3ltGU tucked up in the chassis behind the fuel
tank but foward of the towbar, on the RHS just inside the angled corner strut, there's a length spring wire that sticks out about 6 inches. Buxxxered if I can figure out what it's supposed to do.
Any one else seen it ???
Reply By: Member - Woodsy - Thursday, Sep 16, 2004 at 08:02
Hi Cocka,
just a thought. Is it attached to a weld? Maybe just a length of MIG wire from the factory chassis welding.
76580
Follow Up By: Member - Cocka - Thursday, Sep 16, 2004 at 08:33
Thanks Woodsy, not a silly thought, it looks similar. But it is really springy, like twannngg.
336383
Reply By: Member - David C (QLD) - Thursday, Sep 16, 2004 at 08:36
Did you buy the car new or secondhand? If secondhand the previous owner may have put springs to the bumper tailights to stop them from popping out all the time. Common mod apart from the old silicone.
76583
Follow Up By: Member - Cocka - Thursday, Sep 16, 2004 at 10:07
Nah. It's inside the main chassis in the channel.
Besides one of the t/lights did pop it's screws on the
Mitchell Plat road in the Kimberly.
C'mon fellers put your thinking caps on.
336401
Reply By: Will - Thursday, Sep 16, 2004 at 10:11
Hi Cocka I had a similiar piece of thingy on my Jackaroo which had me puzzled for a while. When the tow bar was fitted they tacked on a piece of old welding wire onto one of the bolts that went into a hole that was difficult to reach by hand.
It held the bolt while they put on the spring washer and nut before tightening.
Will
76600
Reply By: Peter Guy - Thursday, Sep 16, 2004 at 10:47
I Have a 98 GU Patrol and I know the part you refer to. It is supposed to be there and is original. I too am stumped as to what it does. I think it may have something to do with the main fuel / sub
tank transfer process.
If I'm wrong please correct me!
76606
Reply By: Member - Michael (NSW) - Thursday, Sep 16, 2004 at 11:01
Hey... I know, Its the antennae of the tracking device that the Government placed on the vehicle.....You are being watched............:0)
76610
Reply By: madcow - Thursday, Sep 16, 2004 at 12:14
I have seen this before. I believe it is to allow a bolt (generally) be placed in an "out of the way" area so it can be tightened via a nut that is accessible. Is there such a thing in your car? They usually use a lockwasher also to stop the bolt spinning whilst being done up.
Cheers Dave
76616
Reply By: Member - John (Vic) - Thursday, Sep 16, 2004 at 12:38
It's not a thingy.
It's a "Do Dah" and you should consider yourself lucky to have one, it shows that you own a real 4wd.
If you don't own a "Do Dah" you don't know what your missing , it allows you to go
places yoy never dreamed of.
So just enjoy it.
76618
Reply By: Wombat - Thursday, Sep 16, 2004 at 12:54
I think if you ask Nissan you will find that the technical term for it is a "whatsamacallit" and it is there to stop the thingamajig from going kerphut or whang!
76622
Reply By: Member - Roachie (SA) - Thursday, Sep 16, 2004 at 14:49
A couple of blokes have already given you the correct answer. If you have a towbar fitted, you will notice there are nuts underneath the chassis which hold the tow bar onto the chassis. The bolts that these nuts go on have to be fitted inside the chassis rails (both sides). As they are about a foot from the end of the chassis, there is no way of getting a spanner onto the head of the bolt, so they weld a piece of wire to the side of the hex head and jockey the bolt into position using the wire.
76633
Follow Up By: Member - Cocka - Thursday, Sep 16, 2004 at 20:01
Ahhhh. Now I'll rest easy tonight.
Thanks all for setting my mind at rest. Only at ExOz can you get a definitive answer, what a team.
336468
Follow Up By: Member - Bradley- Thursday, Sep 16, 2004 at 21:17
Spot on roachie, but i must say i loved some of the 'paranoid' responses above :-)))))
336476
