gps+laptop+usb ports
Submitted: Thursday, Sep 16, 2004 at 21:35
Member- Rox
Looking for a laptop to travel oz. needs are
#1 usb for digital camera,
#2 serial port for gps,
#3 cd burner to back up copies and send discs to relos,
#4 dvd player(keep the kids ocupied on the black top (rarley))
I have found that new laptops ( not yet purchased) dont come with serial ports, I have read the archives and found that you can run osi explorer via serial/usb cable how ever I just purchased osi and it says serial port required. does any one have any problems with this?
Magellon gold, osi explorer, dicover oz, raster 250k are what i have @ present.
Reply By: Member - Mungo Explorer (NSW) - Thursday, Sep 16, 2004 at 21:43
I use Oziexplorer and my laptop doesn't have a serial port either. Use USB to serial adapter, no problem - although I don't use the laptop in the car, this is just for up/downloading waypoints and
routes. Shouldn't make a difference though.
76703
Reply By: Member - Jack - Thursday, Sep 16, 2004 at 21:49
Hi Rox:
That is strange. I have an old Toshiba Portege - nothing flash. Runs Win98. It has both a serial port, and a USB port ( to which I have added a 4 port USB Hub, plus a plug in CD Reader. No DVD and no burner, but I am sure that if I would be able to buy an external burner and the appropriate software and it would burn CDs (very slowly I should think). I do think it would die under the weight of running dvd. But if this model has those features, I'd start looking at what Toshiba have on offer.
I have my Magellan 310 GPS (I think Noah had one ....) hooked into the OziExplore and the Raster Maps and it works a treat.
I usually copy my digital pics onto the hard drive and download them to my good computer once I get home. Oh - I also have a Dick Smith Card Reader ($40) to transfer these piccies (connects via the USB hub) to the HDD. If I wanted to go the extra yard (metre?) I could fit up a phone connection and email them.
I keep it (the laptop) running with one of those Kerio power sources which connects to the ciggie lighter. I also got that from Tricky Diccy.
But this computer is pretty old, so I am sure the newer ones would have the extras you want.
Just as a
point of interest, I bought 4 of these things at an auction for $60 the lot. Three of the 4 worked. I cannibalised the remaing one for battery, disk drive etc and other bits.
This may help you in your search.
Jack
76705
Reply By: Utemad - Thursday, Sep 16, 2004 at 22:07
If looking at Dell, the Latitude range has serial and parallel ports, Inspiron does not.
I find the laptops that are designed to be lighter/smaller than the normal laptop do not have the serial/parallel ports. Although Dell Inspiron are heavy suckers.
My 14 month old HP Pavillion ze4315 has them.
76713
Follow Up By: Member - Brian (WA) - Friday, Sep 17, 2004 at 18:12
My HP pavilion ze4103 has DVD player.usb& serial ports use ozi with
garmin I have had it about 2yrs. I think when I was looking around to buy one not many had serial ports.
cheers brian
336575
Reply By: Jim Boot - Thursday, Sep 16, 2004 at 23:17
I have to agree with Utemad you can get laptops with serials in any brand
Jim
76723
Reply By: Member - Clive G (WA) - Thursday, Sep 16, 2004 at 23:40
I have a Dell laptop also purchased with it a docking station called TARGUS (USB port Replicator with ethernet) very handle plugs into usb port on laptop and run your GPS from that, also comes with extral sereil ports and usb ports plus one ethernet port.
Clive
76726
Reply By: Member - Sand Man (SA) - Friday, Sep 17, 2004 at 07:39
Rox,
You say you want a CD burner and a DVD Player for your requirements.
If you buy a Laptop with a DVD Burner, you will have both in one unit.
The DVD burner will also burn CD's and play DVD's.
It is highly unlikely you need to use both at the same time.
76742
Follow Up By: Member- Rox (WA) - Friday, Sep 17, 2004 at 08:19
Yes thats what I mean all in one unit, I made a distinction between dvd player & burner as I dont need to burn dvd's.
What i need to know will gps, discover oz & osi explorer run from a usb port via addapter?
336510
Follow Up By: Member - Mungo Explorer (NSW) - Friday, Sep 17, 2004 at 10:19
As I said earlier, yes. From the Oziexplorer website:
My PC only has USB ports (does not have a serial port), how do I connect my GPS
You need to purchase a USB to Serial Port adapter. These come with a driver which will add a virtual serial port to your PC.
You need to note the port number which is configured by the adapter. (if you do not know, check the port number in Windows Settings / Control Panel / System / Device Manager)
In OziExplorer configuration, select this as the serial port to use.
336525
Reply By: Bob of KAOS - Friday, Sep 17, 2004 at 08:38
I use a 3 yo 700 MHz Toshiba satellite which does all the above except burn CDs. To do that you would just upgrade the optical drive to a Combo drive, or use an external CD burner. 3 yo laptop costs 6-800 dollars.
76752
Reply By: Truckster (Vic) - Friday, Sep 17, 2004 at 09:29
1) what is your budget.
2) do you want new or used?
I dont really know of many new laptops that come with serial ports anymore... we have 12 new T40 IBMs here which we cant use cause they dont have serials.. USB to serial adapters wont run with our inhouse software :(
Look at some older laptops which will also save you a fortune, you dont need much to run Ozi! I Thnk Ray had a Pentuim 350 running it...
But depends what else you want to do.. Since you want to run DVD's etc, go for 1Ghz or better, 256 RAM, etc. External CD burners are only $200 in a case. But go with a DVD burner, you can play DVD on them as
well, saves having heaps of CD drives
76763
Follow Up By: Member- Rox (WA) - Friday, Sep 17, 2004 at 18:05
laptop . com has them 700-$1000 I can get them $1250 new 2.4 GHz + $180 xp sounds better to me
336572
Reply By: Willykj - Friday, Sep 17, 2004 at 17:47
Hi Rox,
I purchased a Dell Inspiron just a couple of months ago and it does have a serial port. It also is extremely thin and light so some of the previous info is incorrect.
I use it to connect to GPS & use ozi explorer. Jusr returned from a trip to
Cape York & it all worked fine.
I made lots of enquires prior to purchasing & the advice from many peole was to ensure I got a serial port. Appartently a USB/Serial should work OK but many people have had problems with some combinations of GPS/Drivers etc etc.
I use my laptop for the same reasons that you are looking at. The
Cape York trip involved over 1000 photos - I burnt a back up & on my return burnt a DVD with 700 photos with titles & music etc.
Also used the laptop for internet use via mobile phone (CDMA with USB connection). This worked great,
Have fun,
Willy
76830
Follow Up By: Member- Rox (WA) - Friday, Sep 17, 2004 at 18:06
Is that the model #Dell Inspiron?
How much $ ?
336573
Follow Up By: Willykj - Friday, Sep 17, 2004 at 18:11
It is Inspiron 600. Cost was $1900 which included a CD/DVD burner.
I am very pleased with it..
Willy
336574
Follow Up By: Utemad - Friday, Sep 17, 2004 at 23:16
Within my family there are 3 <12 month old Dell Inspirons. 1x 1100 and 2x 5150. None of these have a serial or parallel port. Your 600M is the only exception I believe. As you have said it utilises a different case to the other Inspirons.
336600
Follow Up By: Member - Clive G (WA) - Saturday, Sep 18, 2004 at 00:26
I have a dell inspiron 5150 , and it has not got a seriel port for my GPS, hence the Port replicator,
Clive
336604
Reply By: Member - W.Wallace - Saturday, Sep 18, 2004 at 16:06
I have a Dell Inspiron 8600 and it has 2 usb ports, 1 serial port, 1 parallel port & a video port for connection to tv etc.
76916
