80 series diff oils
Submitted: Saturday, Sep 18, 2004 at 13:04
ThreadID: 16367 Views:23679 Replies:3 FollowUps:2
96 80 series diff oil in rear lsd do we use 90 oil in rear as well in front
Reply By: Bob Y. - Qld - Saturday, Sep 18, 2004 at 13:57
Russ,
We use Shell "Diff Oil" for a '97 80 series, in both front and rear. Also use the same in 2 79 series work utes and a 100 series dual cab, in rear diffs, and Shell Spirax 85W/140 in front.
Never had a problem that I could relate to the oil. Just the occasional tojo diff "hissy fit". Good to change the oils regularly, every 40K or less.
Hooroo...
AnswerID: 76907
Follow Up By: russell g - Saturday, Sep 18, 2004 at 19:00
thanks bob l was getting different answers to which l should have in them manual says lsd 90 rear but does not say front shell says 90 front and rear so l put 80/90 front gearbox looked like it had auto oil in it emptyed nearly 7lts
thanks russ
FollowupID: 336651
Follow Up By: Member - DOZER- Sunday, Sep 19, 2004 at 11:45
Gday Russ
You will find your gearbox will become hard to shift...all cruiser boxes hate 90 grade especially in the cold climates...best oil for it is Castrol vmx-m 75-90, transfer and front diff, any 90 grade ep oil, rear ls90. There is no problem running ls90 in the front either, just more expense.
When you put ARB lockers in a diff, LS90 is recommended to assist the orings wear. For those who dont know, ls90 has friction modifiers added to the oil, which will interfere with synchros etc.
FollowupID: 336680
Reply By: Bignicko - Saturday, Sep 18, 2004 at 22:13
I have looked after a fleet of Landcruiser for over 4 years now and to keep things simple I use Shell limited slip diff oil we run it in the front diff with no problems at all product number (P12552 1395240) It is for cars with or without LSD and if your gear box is a little tight in the colder mornings 75/90 gear oil in gear box and transfer case change oils every 40000kms and check the oils after water crossings for contamination
AnswerID: 76952
Reply By: Phil G - Sunday, Sep 19, 2004 at 11:18
Theres no problem with putting LS90 into the front diff - most workshops do this for simplicity.
AnswerID: 77000
