Airconditioning in camper trailer
Submitted: Saturday, Sep 18, 2004 at 18:26
Member - Jan S (NSW)
Given the extent of canvas walls in a camper trailer, eg Coromal, does anyone know if it is possible, or sensible, to install a reverse cycle air conditioning unit in one of these vehcles? We wondered if a cavity could be built in to replace one of the floor level cupboards. If it isn't possible, can anyone offer advice about how to best cool ar warm a camper trailer if necessary?
Reply By: Peter 2 - Saturday, Sep 18, 2004 at 18:33
I have a friend that has a full reverse cycle system in a Jayco dove.
It was fitted under the right hand front bunk, needs a second power cord to provide power so two outlets from the van
park. He used it on a trip around Oz and I have clear memories of it sitting out in the sun at Kona
park in
Kununurra on a 35+ day keepin the inside at a pleasant temp with no effort at all.
It was quite funny seeing the camper sitting there on a stinking hot day all puffed up from the air being forced inside by the a/c, the
park guy reckoned he would have charged them double if he had known about the a/c.
76930
Follow Up By: Member - Jan S (NSW) - Saturday, Sep 18, 2004 at 18:52
Thanks Peter. That's good news. I felt a bit silly even asking the question.
Jan
336648
Reply By: navaraman - Saturday, Sep 18, 2004 at 18:39
The portable evaporative units are pretty effective in the drier regions, no use in high humidity. they are cheap to buy and run,
76931
Follow Up By: Member - Jan S (NSW) - Saturday, Sep 18, 2004 at 18:53
Thanks Navaraman. That may be the way to go if we can't manage the reverse cycle air conditioner.
Jan
336649
Follow Up By: Peter 2 - Saturday, Sep 18, 2004 at 19:28
I would reckon you could just fit a window rattler under the bunk and that would do the trick, it could sit on the floor, just have a lift up door on the outside to open when it is in use.
We did give the fella that had the airconditioned dove a hard time and he could only use it when conn to 240v as the gennie was nowhere big enough to run it and we bush camped mostly ;-))
I've got a window rattler for sale here in Hornsby,
Sydney that would do the job.
336652
Follow Up By: Member - Camper (SA) - Saturday, Sep 18, 2004 at 20:29
You might run a portable evap unit on an inverter- they don't take much power.
Camper
336654
Reply By: Member - Jeffrey - Saturday, Sep 18, 2004 at 19:32
Hi Jan S
Last hols I installed a small air conditioner into our caravan,it worked a treat,In my case I mounted it in the window and jiged out some ply to fill the air gap..worth the effort,just remember to vent the rear of the conditioner as it will leak condo.
Hope this helps
Jeffrey
76940
Follow Up By: Member - Highlands - Sunday, Sep 19, 2004 at 09:10
Thanks Jeffrey. That's good to hear.
336675
Follow Up By: Member - Jeffrey - Monday, Sep 20, 2004 at 07:44
Hi Jan S,
Just reading some of the other posts,the method I used is not a permanant fixture,it (aircon) travels secured to the louge with a couple of hoky straps,set up time..irelevant campared to comfort...5 mins
All The Best In Health And Wealth
Jeffrey (AKA JD)
336753
Reply By: Member - JohnR (Vic) - Saturday, Sep 18, 2004 at 20:35
Hey Jan, it is important to think that the walls of the camper trailer are like your canvas jeans. No suggestion of insulated caravan walls in your question. They are not like the R rating of walls at 1.5 in insulation in your house. I understood people went for warmth not to be plagued with window rattlers as suggested above. The more canvas the greater the power of the aircon you will need. Perhaps you better take a heavier trailer to carry it......
Am shaking my head here
76944
Reply By: Member - Jack - Sunday, Sep 19, 2004 at 06:11
Hi Jan:
This may interest you.
Air Conditioner on eBay
Jack
76971
Reply By: Member - Brian (Gold Coast) - Sunday, Sep 19, 2004 at 07:33
" The more canvas the greater the power of the aircon you will need. Perhaps you better take a heavier trailer to carry it...... Am shaking my head here"... wrote JohnR (Vic)...
and to be truthfull so am I.... perhaps you could put ducted air in and mount the system beside the
spa pool motor.. :-)
Some friends of ours bought a tent last year and went "camping" at Christmas... we visited them at the
park they were staying at and they had the TV, the toaster, the jug, I'm surprised they didn't take the bar fridge and microwave!!!! LOL...
Am not against having a few luxuries but air con kinda takes the "outdoors" indoors doesn't it???
76973
Reply By: sean - Sunday, Sep 19, 2004 at 08:24
Jan
I have a 1/2 horse window type airconditioner (not reverse cycle) and I mount it into an open window and sits on removable brackets. The brackes were made from bits from bunnings and cost about $30.00
Ac new cost $299. It can be started on a yamaha 1kva inverter (just) and then easily be run and cools the poptop van beautifully.
If you want one that can be run on a genny, check the running amps becuase these vary alot and go for lowest value possible to make sure the genny will start it.
Sean
76977
Reply By: Nudenut - Sunday, Sep 19, 2004 at 08:57
Jan...dont go and buy a refrigerated unit and then get someone else to install...you could purchase one that is not suitable ie required capacity/size
Get an expert to assist with the required size first. One of those small wall split systems should do the job as would a standard thru the wall (RAC [Room airconditioner]) unit. But rember, these are not designed for abodes that move from place to place. Vibration etc etc could take its toll on the unit.
But then again I have seen lots of units sticking out the back windows of caravans...but these generally stay on bitumen.
76979
Follow Up By: Member - Highlands - Sunday, Sep 19, 2004 at 09:09
Thanks. That's wise counsel.
336674
Reply By: Rick Blaine - Sunday, Sep 19, 2004 at 16:19
I have just installed evap ducted in my house so I have for sale a portable refigerated unit with a flexible hose to duct the heat from the van outside I also have 2 evap units one large one small... email me if you are interested.
77030
Reply By: Mad Dog (Victoria) - Sunday, Sep 19, 2004 at 16:44
I had a split system installed in my ex Goldstream camper during manufacture. If my memory serves me
well it was an Electrolux Blizzard. Worked
well and keeped us cool but a little noisy.
77032
Reply By: Wombat - Monday, Sep 20, 2004 at 12:31
Hello again Jan,
When we were at
Katherine in July we were camped near a Silhouette which had a roof top air conditioning unit fiited into the vent cavity of the wind up fibreglass roof. It looked like a professional fitting as there were two braces added to distribute the weight across the width of the roof. From memory the camper came from Coromal
Adelaide so it might be worth making a call to them. I don't know how much the additional weight would affect the strength required for the winding mechanism, though.
I also forgot to mention on Friday night if you order the 420 X1 get them to change the hinge across to the left hand side of the fridge so that the opening faces the centre of the camper. It is very easy to do and the way it comes as standard is a PITA as anyone sitting on the front lounge has to move to access the fridge.
77111
