Prado gearbox question
Submitted: Wednesday, Sep 22, 2004 at 20:04
ThreadID: 16487 Views:2467 Replies:4 FollowUps:5
Can some one explain what the difference is between (High) & (High Low) on my 2000 prado?
And when I am in (Low Low), is the limited slip still active?
Reply By: Jim-Bob - Wednesday, Sep 22, 2004 at 20:55
G'day Megajones.
Your transfer lever has H, HL, N & LL on it.
H is high range.
HL is for high range with the centre diff locked.
N ie for neutral.
LL is low range with centre diff locked.
Your limited slip diff should be working at all times.
Hope this helps.
Safe travels
Jim-Bob.
AnswerID: 77471
Reply By: Howard - Wednesday, Sep 22, 2004 at 21:11
Is there a slippery diff on both front and rear axles?
AnswerID: 77473
Follow Up By: Jim-Bob - Wednesday, Sep 22, 2004 at 21:27
G'day Howard.
The Prado only has a slippery diff in the rear.
Safe travels.
Jim-Bob.
FollowupID: 337077
Reply By: tour boy - Thursday, Sep 23, 2004 at 07:12
The current series 2 on some GX and most GXL that are fitted with traction control have LSD in both ends.
AnswerID: 77495
Follow Up By: GO_OFFROAD - Thursday, Sep 23, 2004 at 11:20
well, sort of, they use brake pressure to make the wheel with least traction think it has traction, transferring drive across the axle,a cting like a lsd, only better.
FollowupID: 337122
Reply By: tour boy - Thursday, Sep 23, 2004 at 11:35
Generally thats how they work but my mate has a GX with traction control and the diffs have LSD stickers on them and the axle codes on the ID tag are that of LSD.
AnswerID: 77532
Follow Up By: ginga - Thursday, Sep 23, 2004 at 18:56
on a 2000 model?
FollowupID: 337189
Follow Up By: tour boy - Friday, Sep 24, 2004 at 07:17
2003 model series 2. the series 1 and 2 look the same with the exeption of the engine size sticker on the side of the rear turret eg 4000 or 3000 being 4l V6 or 3lTD
FollowupID: 337245
Follow Up By: tour boy - Friday, Sep 24, 2004 at 07:18
sorry forgot to add his is a 3lTD auto GX
FollowupID: 337248
