diff oil which oil?
Submitted: Friday, Sep 24, 2004 at 17:59
ThreadID: 16539 Views:3983 Replies:4 FollowUps:4
seeing as I got such good responses to my q on changing diff oil I thought I would ask what viscosity? 80/90 would be the logical starting point but my auto patrs retailer insists that I would be better off woth the next viscosity up (I think it is 90/120) his reason is that it is a 3 tonne campervan running hj75 diffs (before the front ones shrunk) and the constant load would be better served with thicker oil. I would dismiss him as a counter jockey but he seems quite knowledgable and performed the inspection on the campervan.
Reply By: Bob H - Friday, Sep 24, 2004 at 19:59
Hi Davoe,
Are the diffs l/slip or not??
if they are make sure you put l/s oil in.
AnswerID: 77740
Follow Up By: Davoe - Friday, Sep 24, 2004 at 20:03
nuh first thing I did when I got it was give it a happy birthday all fluids change. Unsure bout the diff so I drove it round to my freindly tyre place and they jacked the rear up with a big trolley jack and spun the wheel, one went one way and the other turned oppisite
FollowupID: 337349
Reply By: Rossco100series - Friday, Sep 24, 2004 at 20:00
Dave try www.shell.com.au and go to lube recommendations 90w/120 is to thick I use 75w/90 XGO ( shell ) which is full synthetic. Using oil that is not recommended for the vehicle can leed to problems. The only time I have used oil that thick was in my old HSV Clubsport V8 but that was Holden recommendation and that is the only time.
Dave even try www.castrol.com.au or www.mobil.com.au or www.bleeps.com.au there are more site's but the info these have should put you on the right track.
Rossco
AnswerID: 77741
Follow Up By: Davoe - Friday, Sep 24, 2004 at 20:06
I would be happy to go with the oil I used last time penz 80/90 except for what the auto parts guy told me. I am no mechanic but I am worried thicker oil may not lubricate well when cold as the higher viscosity wont allow it to splash around
FollowupID: 337350
Follow Up By: Davoe - Friday, Sep 24, 2004 at 20:13
hmmmmm shell website said to use 90ls on the back and front diffs - doesnt sound right to me some usefull info though ta
FollowupID: 337354
Follow Up By: banjodog - Saturday, Sep 25, 2004 at 06:09
Some years ago I arranged a Castrol rep to do a presentation to our staff. He went through all the Castrol product range - brake fluid to the hypoid oils.
One comment that has always stuck in my mind was the one about diff oils - "If at all possible use the LSD 90 oil for the standard open diffs as it has a better lubricating factor when compared to the standard 85/140 grade".
FollowupID: 337373
Reply By: Member - 'Lucy' - Friday, Sep 24, 2004 at 21:38
Davoe
I take it from your post that your diffs are out of a Toyota 75 series.
If so, I have just had a look at the specs for my 75 series Troopy and it states
" above -18C SAE 90".
So there you go.
Ken Robinson
AnswerID: 77758
Reply By: Rossco100series - Saturday, Sep 25, 2004 at 09:43
Davo
Lifting the diff and spinning a wheel to check that it is a LSD does not always show u the right thing. The 75 series does for memory come with a LSD rear diff. And using a 90w lsd oil in a non lsd is still ok just a bit more expensive for the oil.
Davo check mobil and the castrol site as well
Rossco
AnswerID: 77791
