CAMPERTRAILER KITCHEN ON TAILGATE
Submitted: Tuesday, Sep 28, 2004 at 08:04
ThreadID: 16607 Views:2458 Replies:5 FollowUps:8
I am building a kitchen to attach to the tailgate of our camper Barrys' kitchen mark III, my question is how are the kitchens attached to your campertrailers i need ideas to attach it securely.
Baz.
Reply By: fatz - Tuesday, Sep 28, 2004 at 08:30
Baz,
just fitted a kitchen to mine. I fixed a piece of 50 X 50 angle, the lenght of the kitchen, to the tailgate and then cut a slot in the back of the kitchen so it slips over it. The bench top of the kitchen sits on this angle and is screwed to it. I then put some small tabs at the bottom to keep it in place. The kitchen I have made is fairly "robust" but not that heavy, actually lighter than the slide out one I had and holds all i want. I'll try to email you a drawing of what i did.
Mick
AnswerID: 78020
Follow Up By: Baz (NSW) - Tuesday, Sep 28, 2004 at 09:03
That would great photos would help, i was going to bolt 3 L shaped brackets to the tailgate and attach it that way but i'm not so sure that would be the way too go.
Baz.
FollowupID: 337597
Reply By: flappan - Tuesday, Sep 28, 2004 at 08:57
Eh Baz.
MInes bolted with 6 Cup head bolts through the Tailgate and into the back of the Kitchen.
AnswerID: 78022
Follow Up By: Baz (NSW) - Tuesday, Sep 28, 2004 at 09:05
Did you put a bracket inside the kitchen for the bolts as added strengh.
FollowupID: 337598
Follow Up By: Baz (NSW) - Tuesday, Sep 28, 2004 at 09:09
"strength" derrr.
FollowupID: 337599
Follow Up By: flappan - Tuesday, Sep 28, 2004 at 10:26
No I didn't.
I use 1/2 inch cup head bolts , with big washers on them. The Kitchen is made out of 12mm Ply. For me , I cant see how a bracket would make any difference , because its the construction of the kitchen that is the issue.
If its going to break away , its because the back of the kitchen unit , isn't attached to the rest of the kitchen properly. In which case , a bracket wont help.
Bearing in mind a couple of things though.
I have an extendable leg , for support when the Kitchen is open.
I haven't yet , but , I going to put a rail along the bottom , to support the kitchen , on the floor of the trailer , when its closed. So it isn't completeted supported by the Tailgate.
(PS, I cant leave messages on the CT Forum at present , hotmail box is full , but there is piccies of my Kitchen in the Kitchen Piccies folder. I don't think there is any of it mounted though. If you want to chat about it , or want some more piccies . . . let me know.)
FollowupID: 337609
Reply By: cokeaddict - Tuesday, Sep 28, 2004 at 10:21
Hey Mick, if ya get time, I'd be interested in seeing them too if thats ok !
Got the LPG bottle brackets all done and look great. Been years since i used a welder but after a couple of zaps on some scrap metal it all cam back to me. So now I'm in the mood for modifications again. and a sink is a must !
AnswerID: 78044
Reply By: fatz - Tuesday, Sep 28, 2004 at 12:57
I'm in Melb untill Thursday afternoon. I'll try to get some shots on Thursday night if thats not too late.
mick
AnswerID: 78066
Follow Up By: Truckster (Vic) - Tuesday, Sep 28, 2004 at 13:22
Where in Melbourne are you, could meet for a coffee somewhere one day.. Im workin in Nunawading..
FollowupID: 337646
Follow Up By: Baz (NSW) - Tuesday, Sep 28, 2004 at 13:34
Thanks mick thats fine.
FollowupID: 337649
Follow Up By: fatz - Tuesday, Sep 28, 2004 at 15:05
Hey Truckster, working between Mulgrave office and Knoxfield warehouse. Not in the Habit of meeting strange men for a coffee, but would make an exception for a legend such as yourself...........
Mick
FollowupID: 337667
Follow Up By: Truckster (Vic) - Tuesday, Sep 28, 2004 at 23:27
Im up coldstream hills installin new server tomorrow, but day after should be sweet...
FollowupID: 337739
Reply By: Vince NSW - Wednesday, Sep 29, 2004 at 10:20
Baz,
Forget all of the above and wait till Hill End. There you will see the best kitchen ever built.(Istill have to get the water pump working)
Its all made of alloy and slides out.
Vince
AnswerID: 78197
