91 Terrano Cooling suggestions
Submitted: Wednesday, Sep 29, 2004 at 12:31
ThreadID: 16642 Views:2636 Replies:6 FollowUps:7
I need to know if anyone has upgraded there cooling system for the 91 terrano (manual). My radiator as I can tell is two small for the climate we are in (HOT). Will getting a radiator from and Aussie pathfinder be larger and drop temps so that i don't boil coolant al the time.
SantaAus
Reply By: Utemad - Wednesday, Sep 29, 2004 at 12:35
Quick trip to a car yard would tell you that.
Have you thought of getting your cooling system flushed?
Check fan belt, water pump etc
AnswerID: 78210
Reply By: Rob! - Wednesday, Sep 29, 2004 at 13:10
SantaAus
See here for Oscars answer a simmilar question.
and here
R.
AnswerID: 78213
Follow Up By: Rob! - Wednesday, Sep 29, 2004 at 13:14
BTW
The service manual shows that the TD27 engine for Australia (ie not the grey inports) are fitted with a Sub radiator with it's own special fan. No idea where it would fit though, but it may be worth exploring.
R.
FollowupID: 337781
Follow Up By: SantaAus - Wednesday, Sep 29, 2004 at 13:25
No idea what a sub radiator is? are you able to scan that page/diagram and post it?
FollowupID: 337783
Follow Up By: Rob! - Wednesday, Sep 29, 2004 at 13:31
What's your email adress?
FollowupID: 337785
Follow Up By: SantaAus - Wednesday, Sep 29, 2004 at 13:38
dunwellr@itxtreme.com.au
FollowupID: 337787
Reply By: Brian B (QLD) - Wednesday, Sep 29, 2004 at 22:05
My son has one of these and his has an additional thermo fan installed on the grill side of his radiator. This was done by the previous owner we believe.
This works well as without it the vehicle does run hot especially while in 4wd.
As far as I know, the fan is just wired to his ignition switch and only runs when the engine is running.
Hope this helps a bit.
AnswerID: 78277
Follow Up By: SantaAus - Wednesday, Sep 29, 2004 at 22:14
Thanks for the idea, I have a spare electric fan laying arond somewhere. might try and fit it on the weekend and see what she does.\
SantaAus
FollowupID: 337845
Reply By: Member - Oskar (Bris) - Wednesday, Sep 29, 2004 at 23:11
SantaAus
G'day
I suppose you've read all the info I posted previously.
The radiator in the earlier 2.7l petrol 4 pot was a 1 row job so that won't be any good to you... maybe the V6 had a bigger one.
Eventually I repacked the viscous hub with fresh silicon oil (Toyota sil. oil about $14 a tube) and that made the most difference of anything I tried. It still gets warm but nowhere near what it used to.
There are a couple of tricks to doing a good job here, let me know if you want some advice.
I'm not sure that there is room behind the grill for another fan, at least not with the air con. condensor sitting in there. But if someone has already done it, who am I to argue.
The sub-radiator refered to in the manual is for the E24 series (whatever they are - the E20 was a van) with the TD27 engine, but where you would fix the sub-radiator in the Terrano is a mystery to me though.
Anyway feel free to contact me.
"oskarnatski at hotmail dot com"
Oskar
AnswerID: 78283
Reply By: Member - Oskar (Bris) - Wednesday, Sep 29, 2004 at 23:16
I don't know if it makes any difference but there was a suggestion made on this forum about posting email addresses. (see my response above)
Someone said that posting in the long form stops shysters trolling forum sites automatically scanning for addy's written in the normal format.
Seemed to make sense to me anyway.
Just some advice but you may be a wizz at all this stuff (I'm just an unco at it)
Oskar
AnswerID: 78286
Reply By: theshadows - Thursday, Sep 30, 2004 at 09:11
The best option would be repacking the silicon hub and flushing you radiator. As Oskar has alreaady said the larger v6 cooler will fit in nicely as well.
shadow
AnswerID: 78300
Follow Up By: Member - Jeff M (WA) - Thursday, Sep 30, 2004 at 18:13
theshadows is spot on the money, I did just that to my 3.0td surf and it worked a treat, I don't care how good you "think" your fan is locking a couple of tubes of that silicony stuff will make the difference. I though mines was locking up good, but it wasn't. You probally don't need a bigger radiator, especially having a manual, but I spose it wouldn't hurt, just keep the cooling system in top notch condition and you should be right. Flush every year, instead of every other year. Also use good coolant, not that crap you buy from k-mart, genuine Toyota stuff I've heard is some of the best around and its what I have in mine now. I've even heard other nissan owners say good things about toyota coolant.
P-)
FollowupID: 337930
Follow Up By: SantaAus - Thursday, Sep 30, 2004 at 20:50
Went to a radiator place today and they basically told me to use simular things. One thing i forgot to ask was what silcone do you you use to pack? Brand/What's it simple/techincal name?
Thanks Guys
SantaAus
FollowupID: 337945
