Turbo timers
Submitted: Wednesday, Sep 29, 2004 at 18:49
ThreadID: 16657 Views:5386 Replies:8 FollowUps:4
Might stick a turbo timer on the patrol 3.0tdi.
Do I need to or what?
It can't do any harm....but which one do I get?
I understand there are some that 'plug in' behing the ignition and others that take a bit of fiddling around.
What's thest option and how much moola $ will it cost me.
Reply By: theshadows - Wednesday, Sep 29, 2004 at 19:10
Check with your insurance company first ! So companies don't like them. Why dont you just idle the car for 10-15 sec before you turn the motor off or reverse up your driveway ? lot cheaper than a timer.
AnswerID: 78259
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Sep 29, 2004 at 19:26
I agree, If you have a Aston Martin and coming to a quick stop from 200kph, then its probably necessary. But from ordinary speeds to a stop, ehh.. If it was meant to be there,,,, it would already!!!
FollowupID: 337833
Reply By: Bonz (Vic) - Wednesday, Sep 29, 2004 at 20:02
I got an ARB one, about $130 from what I can remember, 10-15 seconds pshaw, idle for a minute or so and it seems like an eternity, better to leave the timer to do it. If you drive more than 30 mins at highway speeds its worth using otherwise theres no value. Also if you have a little stop start at traffic lights then that'll do the same as the timer. Horses for courses I reckon. good luck
AnswerID: 78266
Reply By: ColinD - Wednesday, Sep 29, 2004 at 21:38
Andrew, I used to fit a lot of turbo timers in the country to turbo diesel Patrols. I think they were a brand called Bogart, we probably fitted around twenty or so and never had any problems with them. Having said that, do you need one? The timers I fitted were generally to Farmers Patrols, the utes were often used to tow boom sprays weighing between 2-4 tonne's, the others for some other form of heavy towing. This makes the turbo very hot (glowing) and without a cooldown period, the oil lubricating the turbo after shutdown gets cooked and there goes your seals and bearings! Unless you are towing or sand work, like the other guys said, you may not need one! If it were me I would probably prefer to have an exhaust pyrometer (temp gauge), then you can monitor the exhaust temp all the time to know if you have to idle for a couple to let things cool, these have the added advantage of being able to detect the early stages of engine problems as the exhaust temp rises before the water temp does! Many turbo tractors have these!
Hope this helps........................col
AnswerID: 78272
Reply By: Ian from Thermoguard Instruments - Wednesday, Sep 29, 2004 at 23:13
Hi Andrew,
I like turbo timers (and I don't sell them, OK). Turbo-chargers run with extremely high temperature exhaust gasses running through them - 700 C or higher in some cases. The centre bearing of the turbo-charger is cooled and lubricated with engine oil, and AFAIK, most engine oils, even synthetics, deteriorate (i.e. burn) above about 130 - 140 C. If you are driving on the highway at 100 -110 km/h and pull straight into a servo, your EGT [Exhaust Gas Temperature] could well have been 400 C + before pulling in and still well over 300 C as your pull-up at the pumps. And the whole of the cast iron exhaust turbine housing will be at this temperature. Turning the engine off at this point subjects the now stationary oil in the turbo bearing to extreme temperatures and it 'cooks'.
Our Discovery had an ARB turbo-timer installed when we bought it second-hand and, while I have no connection to ARB, it's been an excellent unit. It has adjustable settings of 0.5, 1, 2, 3, 4 and 5 minutes and an override Stop button.
Since having an EGT gauge [and yes, I now sell these] , I've seen the sort of temps still in the turbo after a highway run and I'm very pleased I have a turbo-timer that lets me get out, lock the car and go into the roadhouse for a coffee while the engine idles down for 3 or 4 minutes until the turbo bearing is cool. [and yes, when we've been continuing on, we have had lots of strange looks from other customers and console operators while we sit in our Disco for 3 or 4 minutes at the pumps before turning-off the engine and filling up - hey, it my engine, OK]
If you are electronically inclined, you can buy and assemble very good quality turbo timer kits from Dick Smith, Jaycar, Altronics etc. If not, you're probably better off buying a fitted device from ARB or similar. If you are somewhere in between, I'd be happy to construct a 'kit' timer for you, that you install.
AnswerID: 78284
Follow Up By: rolande- Thursday, Sep 30, 2004 at 07:00
Ian,
What about an EGT gauge, would prefer one of these to a turbo timer - I have time to let it cool before switching off. Any ideas on who to see, where to go? I am located in country Victoria
Rolande
FollowupID: 337856
Follow Up By: Ian from Thermoguard Instruments - Thursday, Sep 30, 2004 at 11:03
Hi Rolande,
"Any ideas on who to see," - see me! Please visit my website thermoguard.com.au for information on my EGT gauge kits.
FollowupID: 337876
Follow Up By: rolande- Thursday, Sep 30, 2004 at 12:03
Ian,
Loaded question? Will check out the site, thanks
rolande
FollowupID: 337881
Reply By: Truckster (Vic) - Thursday, Sep 30, 2004 at 09:49
I find by the time that you park, unload the people out of the car, you can turn it off without an issue. Same whenyou get home, unpack the car, and shut it down.. theres better things to spend $100 on.
having said that I have a TTimer, but got it off ebay $30.. couldnt turn it down :)
To fit, remove the plastic off steering column, plug in 2 wires, cable tie the main unit up out of way, screw plastic back on, and drive away.
AnswerID: 78305
Reply By: GOB & denny vic member - Thursday, Sep 30, 2004 at 11:08
goodday truckster
you make these things sound so simple as a sparkie i dont have to many problems but theres some out there would say remove plastic ????????????
lol
steve
no work today or easy net access ( im sick)
steve
AnswerID: 78329
Reply By: Puddin & Gumnut (Sydney) - Thursday, Sep 30, 2004 at 16:49
A turbo timer is cheaper than a turbo. I have them fitted to our trucks & the Patrol, it's cheap insurance. In 20 yrs of business only lost 1 turbo & thats because the strap that holds the 2 halves together broke.
AnswerID: 78371
Reply By: Member - Jeff M (WA) - Thursday, Sep 30, 2004 at 18:25
I''m on my second "Silicone Chip" kit turbo timer, you can buy them from Jaycar, Dicksmith, Altronics etc etc. Cost less than $50 and you build if yourself with a soldering iron. I had one in my old Rocky, and I put another one in my Surf, faultless things, works with my alarm and central locking and I have modified it with auto and overide switches so I can use it for warming the car up or leaving pets in with the air con on while you pop in the shops etc. IT also has a temp sensor you can put on your exause manifold that will make it only run when the engine is hot, good for when moving the car out the drive way etc.
AnswerID: 78385
