AnswerID: 78494 Submitted: Friday, Oct 01, 2004 at 12:21
crowie
replied:
Jimw83
I cant really help two much. Much is based on what you intend using the vehicle for. Bush bashing, comuting, family travel etc.
Both are acceptable vehicles and the IO although it has not sold that well is apparently a good capable vehicle. They both work well off road and apart from the really serious stuff probably do the job. In some cases they work better than larger fourbees.
Comes down to comfort, what you can carry, how far you want to go, and intended use. There are others such As the Frontera, Renegade which should also be considered. Jusr remenber that a short wheelbase & firm
suspension does not make for comfortable long distance touring though.
Some thorough research on the net and driving each will determine your ultimatevehicle of choice. Good luck
Reply 1 of 5
