AnswerID: 78781 Submitted: Monday, Oct 04, 2004 at 15:46
Member - DickyBeach
replied:
David,
When we went up the CSR in August last year the spinifex had been well and truly flattened by those who had gone before us.
As to fuel at Well 33, we had telephoned before leaving
Sydney and were assured that fuel would be there, and that the Managers would also be there. Correct on both counts. I don't think the Managers were missionaries but they were certainly good people, and the hot showers and washing machine were great bonuses. The fuel was pricey, of course, but a lot easier than transferring from 44s at Well 23. The store is a dry one and sweets (chocolates etc) are scarce so as to reduce the risk of diabetes amongst the aborigines. Basic fruit and veges and dried/tinned foods were available.
Should you prefer to refuel at Well 23 you could pump the fuel out as follows:
Get a bung for a 44 gallon drum, drill a hole through it and fit the valve stem from a car inner tube, and through the smaller hole on the top of the 44 pass a length of good sized (ie, diameter) plastic tubing. Connect your air compressor to the valve stem and the increasing air pressure will force the fuel up and out the plastic tubing.
Enjoy the trip - we did.
| I want to die while asleep like my grandfather, not screaming in terror like the passengers in his car.
Reply 1 of 7
