Site Search
Section Image
Roper Bar to Borroloola
Submitted: Monday, Oct 04, 2004 at 16:00
Wizard1
Can anyone provide feedback on the road from Roper Bar to Borroloola. We intend towing a caravan. Keep an open mind as we successfully completed the Oodnadatta Track via Painted Desert road. How does the Roper to Borroloola road compare?
Some advice on the Oodnadatta Track was a little less than accurate (I wouldn't tow a van on it with a 2wd car) so we are now bullet proofing the van for the next trip in 2 weeks. We are obviously aware of impending wet season, which we hope to beat...but would appreciate some feedback
Wizard
Darwin NT
Prado TD
Jayco Freedom
Advertisement
ThreadID: 16777 Replies: 6
Views: 532 FollowUps: 4
AnswerID: 78813   Submitted: Monday, Oct 04, 2004 at 20:17
Member - Nick (TAS) replied:
From memory road was pretty good,they were actually there last year when we went through upgrading the road on the northen end and it was like a highway.There are lots of small creek crossings to cross ,the deepest back then only a couple of feet deep.May have changed by now.Also the Oodnadatta track was very good,2wd easily(again last year)
Our Camps - Australian Mainland
Click Image to Enlarge
Our Camps - Mainland Australia
Reply 1 of 6
FollowupID: 338256   Submitted: Monday, Oct 04, 2004 at 22:03
Wizard2 posted:
Well IMHO the section between Oodnadatta and William Creek would leave most 2wd (given low ground clearance with a little stone damage underneath.
The only 2WD I saw were south of William Creek.
AnswerID: 78814   Submitted: Monday, Oct 04, 2004 at 20:22
Jim-Bob replied:
G'Day Wizard1
My Navigator and I travelled down from Roper Bar to Borroloola at the end of August.
As far as we are concerned the road was in a fairly good condition. We towed our Aussie swag c.t with our 89 model 2.8d 4runner and the only problem we had was snapping the u.h.f. aerial off in some of the corrigations down near Tawallah Station.
Some parts of the road had larger stones but like always drive to the conditions and you should have no troubles, watchout for the river crossings some are steep.
We have only driven on a few kilometres of the Oodnadatta track at the Marree end so we cannot compare the two tracks.
Wish we were back there,(just bought 2001 Pray Do TD) want to try it out.
Safe travels.
Jim-Bob.
Reply 2 of 6
AnswerID: 78827   Submitted: Monday, Oct 04, 2004 at 21:41
jon jenkins replied:
We have done both. We did this trip last year but the other way in a GU packed to the gills. If oodnadatta was a 5 on a 10 scale this would be a 7. No major problems but some of the creek crossings are iffy if the water is high and can be a little steep.
Get you misses/nav to stand on the roof and watch for crocs on some of the crossings. I was really scared on some of them and when the water was dark just drove slowly without walking across first.
If you have a look at the piccy here [ View Image]you will see the tricky little ones first hand. There is a hole in the direct line so I had to go right but the water was so dark and with all the overhanging trees I did not want to walk it.
We travelled the whole gulf alone so often at serious crossings we waited till someone else came along so if we got stuck we could pull each other out.
Jon Jenkins MLC
Parliament House Sydney NSW
www.trac.org.au
Reply 3 of 6
FollowupID: 338278   Submitted: Tuesday, Oct 05, 2004 at 08:50
Wizard1 posted:
Jon,
where is the creek you show in your picture?
AnswerID: 78836   Submitted: Monday, Oct 04, 2004 at 21:55
SUNSEEKER replied:
Been through there in Sept. and the road is in fairly good condition but as far as towing a caravan with a 2w drive is concerned I would say that you would have no problems providing your speed is very slow on the corrigated sections and make sure all tyres are in good condition(no fatties) and keep those pressures UP NOT DOWN as most so called experienced guys will tell you.Have done the trip for the last three years with no problems but good tyres and common sense are the secret to all offroad travel.
Reply 4 of 6
FollowupID: 338286   Submitted: Tuesday, Oct 05, 2004 at 09:26
Austravel posted:
I went through in July and thought it was ok, wouldn't like to take a 2wd unless it wasn't mine. Your right good condition tyres are a must but to say pressures should be up is a bit strange. Until I lowered my pressures I found I got heaps of chipping and a number of tread fractures. Since lowering the pressures by up to 10psi from highway pressures I've significantly reduced tyre damage. Just about every tyre place and local I've spoken to in outback regions all tell me to reduce the pressure. Having the pressure up is only asking for trouble.
Activities Index
Revitalise Me Revitalise Me
Melbourne - VIC
Treat your hands and feet to a soothing, relaxing and rejuvenating experience that will leave you wo
Day Spa Pedicure Treatment - Ringwood Day Spa Pedicure Treatment - Ringwood
Melbourne - VIC
Indulge in this heavenly day spa treat for your hard working feet and legs!
Kangaroo Island Personalized 1-Day Escapade Kangaroo Island Personalized 1-Day Escapade
Kangaroo Island - SA
For Wine or Reason specialize in personalized guided Tours, perfect for corporate clients or the ove
Historic DC3 Flight & Lunch At King Island Historic DC3 Flight & Lunch At King Island
Melbourne - VIC
Combine your 2 favourite past times in one on this historic DC3 flight to King Island where you will
Book Now - Things To Do
AnswerID: 78918   Submitted: Tuesday, Oct 05, 2004 at 13:55
Wizard1 replied:
Just to clear things up, I intend towing thw van with a Prado TD, not a 2WD car. Heaven forbid that I would even entertain driving such a trip in a car. I only use my wife's car to go to the shops.
Thanks for your honest and informative replies. A collegue has also completed the trip and advises similar info to yourselves, accept the angles at creek not being an issue.
He describes the road as being no worse than some of the rural dirt road around Darwin.
They say the best part of the adventure is the journey, so we'll see how we go. I was a little concerned about the Oodnadatta Track. Apart from some collateral stone damage it wasn't too bad.
Wizard
Reply 5 of 6
AnswerID: 78953   Submitted: Tuesday, Oct 05, 2004 at 18:40
Hi wiz
The pic is, accoding to the photo album, "dark creek crossing with hole just out of Borroloola" but I cannot remmber which one. The only one that really stands out in my memory out was Calverts (deep, rocky and fast flowing!) but that was definitely the othe side of Borroloola.
None of the creeks are going to give you any real grief, just take it easy and enjoy the trip :-)
jon
Reply 6 of 6
FollowupID: 338440   Submitted: Wednesday, Oct 06, 2004 at 07:14
Wizard1 posted:
Thanks Jon.............
